Question about Summit Appliances Division Refrigerators
Holiday outdoor beverage cooler, model fc07dc1hs. Why isn't it cooling?
    Top Expert:
  • Summit Appli... Master
  • 45,204 Answers
All things fail eventually
Posted on Oct 02, 2015
SOURCE: Beer Not Cold!!!
There is a temperature control knob on the back side of the ref. it is on the bottom by the compressor
Have you adjusted this?
clayfoot
Posted on Sep 27, 2008
Sea Breeze
  • 4654 Answers
SOURCE: beverage cooler not cooling enought
Jeremy, after the line and new filter drier is put in the high pressure side and silver soldered make sure the unit is placed in absolute vacuum for 30 to 60 minutes. It's critical that all air and moisture is remove and the charge applied on low side with out a single air bubble put back in. You may need some on hands help on this solution to get the cooler working properly, Thanks Sea Breeze
Posted on Oct 27, 2007
SOURCE: Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Posted on Mar 02, 2009
shastalaker7
  • 1515 Answers
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
Why isn't it cooling? GE Monogram Beverage Cooler ZDBC240NBS
Sara you question does not tell us a MAKE , or model perhaps you need to search the manufacturer's website for support .
Feb 15, 2016 | Refrigerators
Avanti outdoor beverage cooler (new), should temperature lights go off? How do I know what the temp is, if the lights go off? It appears to go off for no reason. Owners manual mentions door gasket?? I
The temp lights might indicates the actual temp settings havent reach the programmed settings. If its on and off coz it try to recover the temp lose after it drop below prog. Temp. Monitor it first if its cooling must be normal only.
Sep 21, 2014 | Avanti Orc2519ss Steel Outdoor Beverage...
Model mt 17-54 will not cool
Go to page 10 of this PDF=> MT Merchandisers (MT Series) If you do not have Adobe Reader Click=> HERE For Customer Service at Beverage-Air=> HERE Go through pg.10 and that should give all answers you need, Good Luck, Sea Breeze
Feb 23, 2012 | Beverage-Air MT45 Beverage Cooler...
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
Refrigerator isn't getting cold anymore
Check if the compressor is running. If not, test for power to the compressor. If the compressor feels very hot, and you hear something clicking, then you probably need a new starting relay which is inside a little box on the side of the compressor. You might have to wait several minutes for the compressor to cool off before it will do its next "click-on" and "click-off" thing. If the compressor is cool, and there is power going to the relay, the overload (next to the relay) could be "open" (no continuity).
Sep 07, 2011 | Beverage-Air CT96Y1B (6.8 cu. ft.)...
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Refrigerators Logo
658 people viewed this question
Top Summit Appliances Division Refrigerators Experts
ray gallant
reliableservice
Brett Duxbury
Brett Duxbury
Are you a Summit Appliances Division Refrigerator Expert? Answer questions, earn points and help others
