Question about ACT Clutch Disc for 1999 - 2001 Nissan Maxima
Won't go in gear when car started
Clutch won't go in gear when car started
  • 14,406 Answers
If it's a clutch,check clutch master fluid,if real low or out,go check clutch slave cylinder,it's bolted on side of transmission,see if it is leaking,if so replace and bleed.You can fix temporary,fill reservoir and bleed,will get you there,done it.
Posted on Oct 27, 2012
Clutch problem. please help??
please go to www. automecanico.com and translate the website with your browser this amazing site and fix it.
God bless you
Jul 08, 2013 | Cars & Trucks
My clutch is soft in my 2000 ford focus . It won't
bleed the air out of the clutch system
Jul 23, 2017 | Cars & Trucks
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
My car will not go into gear unless its started and already in gear. Ill pull it outta gear and won't go back in while running.
Your transaxle will have to come out & new parts installed,
like synchro rings
You should be able to push in the clutch & shift thru all
gears nice & smooth,with no engine running.
That said I wouldn't rule out clutch issues also,but not
for the shifting issues.
Jun 02, 2012 | 1990 Ford Probe
Push on clutch and caR WONT GO IN GEAR UNLESS MOTOR OFF
Some of that model had an unusual clutch mechanism, which has probably broken due to wear. Read here
http://wiki.answers.com/Q/How_to_adjust_clutch_on_1995_ford_escort
In the event yours is instead fitted with a hydraulic clutch, either
- the hose has split
- the clutch throwout lever has broken or collapsed
Mar 21, 2012 | 1995 Ford Escort
The bike will go in gear but the clutch won't
Remove clutch slave cylinder & push piston right in then refit
Ride safe
Bike-Doc
Feb 01, 2012 | 1997 Yamaha YZF 600 R thunder cat
Pickup starts great, goes into all gears but won't move. It's like it is still in nutural.
Assuming the pickup is an automatic, check the transmission fluid. The #1 cause for transmission slippage is lack of Automatic Transmission Fluid.
If the pickup is a standard shift, the pin that connects the shift to the transmission has likely broken. You would still be able to shift from the inside but the gears won't engage. A bad clutch is also a possibility but you would have noticed a burning smell prior to the clutch giving out.
Dec 20, 2011 | Cars & Trucks
My 1998 Honda civic ex won't move but the motor
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right.
Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged.
I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
Nov 06, 2011 | 1998 Honda Civic
1997 Hyundai Elantra - in storage over winter. Can't put into gear when running. Can put into gear when turned off - can then start, clutch depressed, can release clutch and drive but can't shift...
clutch &pressure plate must have got moisture on it & forze together put car in gear & turn car over it should brake free had it hapen to me
May 25, 2011 | 1997 Hyundai Elantra
ACT Clutch Disc for 1999 - 2001 Nissan Maxima Logo
148 people viewed this question
Top ACT Computers & Internet Experts
Thomas Perkins
Thomas Perkins
ray gallant
 steve
steve
Are you an ACT Computer and Internet Expert? Answer questions, earn points and help others
