Question about Whirlpool Washing Machines
My whitemagic machine allows me to select a program and when i press the start button it shows PE error. This is happening since 2 days now.
The machine was functioning perfectly fine till day before and now since yesterday, after i select a program, it shows me a PE Error. Also when i press the buttons for a program selection, the beep sound is muffled...usually the beep sound is audible and loud. I ahve not moved the machine since in the past few months, so there cannot be a loose connection due to movement.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
This is a Pressure Sensor Error.
Remove the top of the washer. The pressure is usually located at the top. It will have a plastic tube about 5/16 in size. Remove the tube and blow down into it to try and clear any blockage. If that doesn't work replace the pressure switch.
Posted on Oct 27, 2012
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL electronics problem
I’m not sure what machine model you have your in the FAV6800AW forum. I got Maytag CSV to send me a Control Board for my FAV6800AW. Had to do some arm twisting it is under warranty for 5 years. If you think your Control Board or console is under warranty give it a try. They wanted a Cert Svr Tech to diag the problem. I told them my neighbor was a Svr Tech (me) he had diag the problem and would install the part. They sent me the Control Board, it might be worth a try. I have a number spare parts not under warranty and ebay is my 1st choice, Second Choice . I use this for parts look up Sears Parts Direct.
What is your model type? It sounds like you have Service Manual for your machine and you are troubleshooting in the right direction. Do you have surge protection on the 120VAC outlet powering your machine. Good Luck Rich.
Posted on Jun 21, 2009
watugot
  • 290 Answers
SOURCE: F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Posted on Nov 03, 2007
barkencoa
  • 3463 Answers
SOURCE: Program selector knob keeps turning
Difficult to pinpoint problem from symptons.
Try this link, there is a lot of information here which may help you.
www.washerhelp.co.uk/diy-repair-help
Posted on Dec 04, 2008
erickg
  • 116 Answers
SOURCE: when i try a wash i am getting this "PE" error
that is a water level sensor is bad,. turn off water and unplug unit and call in a service tech.
Posted on Apr 29, 2009
dh1200s
  • 335 Answers
SOURCE: "OP" ERROR CODE
Take a look at this post, it’s for troubleshooting an OD alarm but you can follow the same troubleshooting path to see if you have a lid magnet out of position or a broken lead on the magnetic reed relay located in the left lid lock. The lid magnet operates the magnetic reed relay to signal the lid is closed/the lid is open. Try an external magnet on the left bumper and see if that clears the OP error code with the lid open. If it doesn’t I would try reseating the left lid lock plug (possible corrosion issues). If that doesn’t clear the OP alarm it would be time to pull the life lid lock out of the machine and inspect for a broken lead on the magnetic reed relay or other corrosion issues with the left lid lock. The left lid lock is in a location near the bleach dispenser. Links to the SM are in that post and a link for parts look up. Post back if you have questions
Posted on Jun 23, 2009
Pe ERROR WITH WHIRLPOOL MAKE WHITEMAGIC 123 650 h WASHING MACHINE, MACHINE WORKS BUT OUTER BOWL DOESNOT SPIN AND MAKING BEEP SOUND DURING PROGRAMMED
does tube move by hand? does it have the correct amount of resistance when turning, or is it hard or too easy?
Dec 09, 2014 | Whirlpool Washing Machines
How to fix whirlpool whitemagic pro 700 s pe error?
This was answered previously here. Hopefully it works for you.
http://www.fixya.com/support/t13889252-whirlpool_washing_machine_giving_pe
May 24, 2014 | Washing Machines
PE ERROR WHITEMAGIC
PE--Pressure sensor error
Nov 12, 2013 | Whirlpool Cabrio WTW6300SB
White Magic 650H. Why is error code PE displayed and water reuse LED blinking?
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Sep 29, 2013 | Whirlpool Washing Machines
Whirlpool Washing Machine Whitemagic H65 Stainwash user manual
White magic h65.while switching on he showed LE now it's showing PE,how it will resolve
Dec 23, 2012 | Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Jun 19, 2011 | Washing Machines
Hello, I have model 49556/te158wt and I'm not able to set hour ! could you help me ?
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
Oct 12, 2010 | Woods 7 Day Digital Heavy Duty Timer...
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Washing Machines Logo
770 people viewed this question
Dan Webster
Dan Webster
Sal De
