Question about Hotpoint Dryers
Hotpoint Dryer model DLL2650BFLWH won't blow heat
It will tumble but blow no heat
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Posted on Oct 27, 2012
ginko
  • 19396 Answers
SOURCE: no heat in dryer
To test the heating healement you need to access it by taking apart the top and back panel, and test it for continuity using a multimeter.
There are also a couple of fuses/circuit breakers that you should test.
Entering the model number here you get the exploded view, and replacement parts.
Posted on Sep 28, 2008
barkencoa
  • 3463 Answers
SOURCE: my hotpoint aquarouis ctd00 tumble
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Thanks.
Posted on Dec 27, 2008
dragonsthatk
  • 547 Answers
SOURCE: Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Posted on Feb 17, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
  • 1126 Answers
SOURCE: Have Old Hotpoint gas dryer model DLL2650BFLWH.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=207752
Looks like the part number is "AP4379804"
Posted on Jul 08, 2009
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
My dryer wont come on its a hotpoint model #dlb2650bgl the timer is ticking the interior light comes on my husband put a multi-meter on the start switch and shows power what else could the problem be
The first thing I would check is the door switch. If it isn't closed the dryer should not start - although the timer would be active. If it won't tumble or heat then that is the first thing I would check and on Hotpoint that is a high failure rate.
Dec 31, 2011 | Dryers
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
118 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
