Question about Hotpoint TDL15 Electric Dryer
Hotpoint dryer model DLL2650BFLWH not heating
The dryer will tumble and blow air but no heat.
  • 3 Answers
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Posted on Oct 27, 2012
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
barkencoa
  • 3463 Answers
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Posted on Jan 07, 2009
  • 1126 Answers
SOURCE: Have Old Hotpoint gas dryer model DLL2650BFLWH.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=207752
Looks like the part number is "AP4379804"
Posted on Jul 08, 2009
  • 534 Answers
SOURCE: Model NVLR333EVOWW Not heating up
your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
Posted on Jul 22, 2009
apart4u
  • 213 Answers
SOURCE: hotpoint aquarius tdc32s not heating up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 | Dryers
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
My tumble dryer is blowing cold air only. I had a new thermostat put in between 1 and 2 years ago, so hoping it's not that and something else. Can you help me please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 21, 2011 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Does not heat, air blows, drum tumbles.
then DIY we do not read minds as to MAKE
Sep 28, 2017 | Dryers
Hotpoint TDL15 Electric Dryer Logo
120 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
