Question about Homelite 34118154G Ring Gear Assembly
I have a Homelite electric chainsaw, model UT43120. I need to replace the ring gear assembly, part #34118154G. How do I get the old ring gear assembly out of its housing? It appears that there are supposed to be 2 rubber pins, part #34210154G, holding the ring gear assembly in place, but I don't see them.
SOURCE: homelite chainsaw carb adjustments
bear973 you must make sure that that in tank filter is seated in right position and not just floating around inside the tamk
Posted on Mar 24, 2009
  • 630 Answers
SOURCE: Need Manual
Go to jackssmallengines.com/searchdb2.cfm Click parts look up, click parts look up again, choose homelite under select OEM, click homelite, click chain saws, follow down list to model no. and click on it.
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Need owner or service or both manuals for Homelite
I haven't found a location of the operator's manuals but the numbers you provided made the IPL (exploded parts list) easy. Thank You. Go here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; In the "Model Name/Number" type in "UT-10654" and you are there.
Atta boy/girl
Lou
Posted on Sep 23, 2009
SOURCE: Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
  • 4088 Answers
SOURCE: homelite ranger 33cc chainsaw will not start.
Did you check for spark when the plug was out? It should be blue and snappy. If not, you need to expose the flywheel assembly by removing the left case cover, then remove the stop switch wire from the ignition module. If now sparks, check the stop switch and connecting wire for grounding. If still no spark, replace the ignition module. Use a thin businees card for a gap gauge--turn the magnets under the module, insert the card into the gaps, then loosen the mounting screws and let the module stick to the magnets. Tighten the screws and rotate the flywheel to remove the card, then turn the flywheel one full rotation and check that the gap doesn't close up at any point. If the original test had good spark, then pour some fuel mix into the plug hole and attempt start--if you get several pops, then check the fuel system. Start with checking the fuel filter which will commonly plug up over time and check the fuel lines for decay or damage. Does the primer button pull fuel into it when pumped several times? Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and trouble shooting. Note carefully the items within the lower chamber as they are critical to proper running. Hope this helps!
Posted on Jun 17, 2010
What is a convertable drive on a 1964 homelite 51?
Do you mean a C-51? It might be a gear driven low speed saw. I had an old homelite years ago.
Try this posting your question to this forum:
Chainsaw Collectors se
Apr 24, 2014 | Homelite Garden
Homelite xl chainsaw e-ring on bar tightening bolt needs replacing. Where does it go and how do I do it
The original Homelite company has been out of business for many years. Getting parts for them at our repair shop is impossible. I know you can go and buy new Homelite units from the big box stores, but these are not being manufactured from Homelite. Sometimes you can find parts from repair shops that have leftover parts. You might want to call around. You might find them. George
Oct 07, 2013 | Homelite Consumer Products 9.0 Amp, 14 In....
Where can i get a Gear & Pin Assembly for my homelite
I am pretty sure that John Deere still owns Homelite. When I had a Homelite chainsaw I went to a John Deere implement dealer and they ordered it for me.
Oct 09, 2012 | Homelite Factory Reconditioned 26cc...
Chain comes off of homelite electric chain saw ut43120
Make sure the blade is snug on bar. If it is too tight or too loose the chain may kick off.
Sep 26, 2010 | Homelite Garden
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
I have a Ryobi chainsaw Model 10532. I just need to replace the piston & rings in it. Where can I get spare parts?
Call or go online to the Homelite Repair Center. They are very helpful. Homelite makes the Ryobi Chain saws.
Jun 23, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Owners manual for homelite chainsaw
Have your UT# available.
http://odref.com/homelite/chainsaw/index.html
Mar 27, 2009 | Garden
Can't find parts
there are sites on e-bay that scrap out chainsaws and sell the parts. this might help you find something that you need
Nov 12, 2008 | Homelite Garden
Homelite chainsaw carb adjustments
Oct 05, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite 34118154G Ring Gear Assembly Logo
164 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
