Question about Mitsubishi WD-52526, WD-52527, WD-52528, WD-62526, WD-62527, WD-62528 Projector Lamp - 915P028010 - OEM Equivalent
Installing capacitors for wd 52527 mitsubishi tv
SOURCE: Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Posted on Nov 02, 2008
  • 899 Answers
SOURCE: CAPACITOR 1000 UFD 16V 105C FOR MITSUBISHI WD-52525 52 IN. TV
no you cannot substitute a 680uf 16v 105c in place of a 1000uf
if you want to put a better capacitor in place of the old 1000uf 16v 105c , then use a 1000uf 25v or 35v 105c
the voltage rating will allow the cap to better handle the circuit
Posted on Apr 01, 2009
Slinteriors
  • 8617 Answers
SOURCE: tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Posted on Jun 10, 2009
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
  • 597 Answers
SOURCE: Hi: I have a Mitsubishi WD 52527 projection TV.
go to menu...correct brightness
Posted on May 20, 2010
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
My Mitsubishi WD-52527 has a constant blinking green light. There is no video and no audio just a blinking green light when it is pluged in
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options for you.
1. Have it fixed by a professional 2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It'scalled: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.Kaufman605
Dec 11, 2010 | Mitsubishi WD52527 52" Projection HDTV
I have a mitsubishi WD-52527 TV with error code 45
You have to pull the light engine to get to the pbs fan it is the one located closest to the lense on the light engine. you should be able to see if the fan is turning without removing the engine.
Sep 06, 2009 | Televison & Video
No frikin' sound!
Either way the first thing to do if you haven't already is to pull the plug and wait a minute and plug it back in. This will cause the TV to do a hard reset much like re-booting a computer. You can also accomplish this by pressing the reset button on the front panel on some models. If you still have no sound confirm you're getting it from the source. Check for sound with alternate sources like a DVD player or video game.
michtech
Feb 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsu-wd-52527 lamp replacement
The lamp in this TV is very easy to change. I recommend to use your owners manual, but the front cover snaps off, using screw driver open lamp door, unscrew lamp, pull out with handle, make sure lamp is cool. Replace, follow onscreen display to reset lamp hours. Use remote to enter information.
Feb 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52526, WD-52527, WD-52528, WD-62526, WD-62527, WD-62528 Projector Lamp - 915P028010 - OEM Equivalent Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
