Question about Panasonic PT-52LCX66 Projection Television
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Just replaced bulb and nothing happened. Blinks green for a few seconds then red light comes on
  • karlee Jul 16, 2015
    Same here.. did you fix it?
  • Panasonic Master
  • 8,617 Answers
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Posted on Oct 27, 2012
ctf1800
  • 4402 Answers
SOURCE: No picture Panasonic PT-40LC12 40
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
respinoza86
  • 18 Answers
SOURCE: I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Posted on Nov 19, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a Panasonic PT-50LC13
Replace your Ballast Board it is what turns on Lamp call Encompass Parts 1-800-638-3328
Posted on Dec 20, 2009
  • 11 Answers
SOURCE: Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Posted on Jan 26, 2010
My Panasonic PT-52LCX66 worked for about a week after changing the lamp. Now it won't turn on. 3 orange power blinks and 4 red temp blinks. Please help! My husband is to hard to babysit without a TV :)
Three orange power blinks indicates a 'Malfunction 5', and that your unit requires servicing. You can try pressing POWER on the unit for over 7 seconds, and then turning the set back on after 5 more seconds. If this doesn't help the set needs servicing.
If you didn't reset the lamp timer after replacing it, you might try that by following these steps.
If you think browsing the troubleshooting section of your operating manual may help, you can access it here.
I hope that helps.
Mar 31, 2010 | Panasonic PT-52LCX66 Projection Television
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
HOPE THIS HELPS
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX66 Projection Television Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
