Question about Frigidaire ATF6700FS Front Load Washer
ATF6700FS2 E90 FRIGIDAIRE ERROR MESSAGE
E90 ERROR AND BEEPS CAN'T STOP IT OR MAKE IOT WORK WHATS THE PROBLEM
3 Suggested Answers
  • 1073 Answers
SOURCE: Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Posted on May 09, 2008
SOURCE: I have a Frigidaire Front Load Washer during its
The cause of the error is that no cold water is getting through the cold water valve (inside the machine).
The E10 error indicates that one of a group of error codes occurred. The specific code could have been one of the following:
  • E11 - Fill time too long. (See test 1 below)
  • E13 - Water leak in the tub or air leak in the air bell. (See test 2 below)
  • E14 - Dispenser drawer reed switch is open. (See test 3 below)
To recall the specific fault code from this group, follow these steps:
  1. Wake the machine by pressing any button
  2. Wait 5 seconds
  3. Press and hold the Start and Pause/Cancel buttons simultaneously
  4. All LEDs will go blank and after a few seconds the control will signal the stored code
Based on the specific error code, follow the specified test and troubleshooting.
The magnet for the dispenser drawer reed switch is shown in the second image below. If this magnet is missing, you will get the E14 code.
Some of the troubleshooting provided is intended for service technicians. Do not conduct any test or troubleshooting that you are not completely confident that you can safely complete. Unplug the washer before accessing internal components.
http://appliancejunk.com/forums/index.php?topic=1364.0
That website above directly addresses your issue.
Posted on Jun 01, 2010
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
    E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Basic Reset
    One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
    Feb 26, 2014 | Frigidaire Washing Machines
    E90 and continual beeping
    Hello - I am happy to assist you. However, could the error could possibly be an E9? If so, E9 on an All Refrigerator typically indicates a shorted thermistor. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
    Jun 08, 2013 | Frigidaire Refrigerators
    When turned on machine, no lights came up, then all lights lit up and beeped and on panel E90 kept flashing
    An E90 error indicates some sort of communication error between the two boards that control the washer. Usually it's a problem with the wiring. (At least for Electrolux and related washers, E90 is a communication error.)
    You can try unplugging the washer overnight and then trying again. This resets the board. Otherwise, you need to open the washer and use an electrical contact cleaner. Check all the wiring for any corrosion or solder issues. This will be time consuming.
    Alternatively, you could replace both control boards (usually comes a large fraction of the cost of a new washer when you add the repair man's time). You usually can't tell which of the two boards are bad so replacing just one frequently doesn't solve the problem.
    I hope this helps.
    (if you add a comment with the make and model of your washer, I'll check the parts cost/availability if they are at my usual sources.)
    Jun 26, 2011 | Washing Machines
    Machine beeps continuously and display gives an E90 error code. What is wrong?
    If this is a Zanussi washer then E90 indicates a communication error between the interface board (control panel) and the main circuit board. Unplug the machine from the power! and take the top off the machine, if you stand in front of the machine on the left side you should see the main circuit board along with a blue multi-wire cable going from it to the control panel (interface board). There is most likely a poor connection at one end or the other or maybe even both. This will generate an E90 error code. You need to remove the control panel by removing the screws located behind the soap drawer and also the plastic clips located along the top rail, disconnect the blue cable from each board one at a time and then plug back in making sure to firmly seat the connectors. These can become loose from miniscule vibrations from the machine operating. Put everything back together plug back in and it should work.
    Mar 12, 2011 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    An error message E90 is flashing on my Zanussi washing machine (wdj1294 I am not sure if this is correct) and beeping. I can't turn off the error and obviously the machine won't start a wash as I also...
    don't know exactly what e90 means but each time it happens we turn of the power on wall switch for a half hour and the problem seems to right itself
    Jul 07, 2009 | Washing Machines
    Electrolux 1087 E90
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    Electrolux 1087 E90
    When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
    what can i do ?
    Sep 15, 2007 | Electrolux EW1000i Front Load Washer
    Open Questions:
    See all Frigidaire ATF6700FS Front Load Washer Questions
    Frigidaire ATF6700FS Front Load Washer Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
