Question about Linksys Lynksys Etherfast 16-port Ethernet Switch Ef4116 Ver 2.1 10/100 W/powercord
Trying to add my MacPro to my lynksys network.
My airport shut down. I have connected my lynksys router for the network, but I cannot access the network with my MacPro. What am I doing wrong?
  • 28 Answers
If your linksys is set for dhcp,make sure your mac is set for dhcp.
if everything is set and problem still persists,reset the linksys.
Posted on Nov 06, 2013
Airport sign in keep saying wrong password
Delete Preferred Network(s)
  • System Preferences > Network > Select AirPort > Advanced > AirPort tab
  • Under Preferred Network, use the minus button to delete the network(s) you regularly use from the list
Delete AirPort Keychain Entries (Note: only applies if you connect to AirPort/Time Capsule routers)
  • Launch the "Keychain Access" application located in /Applications/Utilities
  • Click on the "Kind" filter at the top, and look for any "AirPort network password" entries...and delete them.
  • Restart, or log out then back in.
Add Preferred Network(s)
  • Under Preferred Network, click on the plus button to add any preferred network(s).
  • Restart or log out then back in.
Jul 02, 2014 | Apple iBook G3 Mac Notebook
I get intermittent wi_fi service. Sometimes it works two days in a row and for the next few days it keeps searching and searching for my Wi-Fi connection. I shut airport off and plug in the hard wire and...
You may have people close to you with wireless using the same channels and interfering with your router. Try changing channels in the router settings or move the router to a different location.
Sep 18, 2012 | Cisco Lynksys Dual Band Wireless N Gigabit...
How to hook up ipad2 16gb to a zyxel mwr211 wireless router
Are you trying to connect to the wireless network on iPad?
Make sure that you have all the settings of your network. If your network is secured then make sure that you have correct network name and password.
See easy steps to connect ipad to WiFi
Jun 27, 2012 | Computers & Internet
How do i find network key for lynksys network
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 03, 2012 | Cisco Linksys Wireless N Home Router...
I changed the settings with help from lynksys and I can not sign on
are you trying to connect to the wireless network or you are trying to access the router set up ?
You can check the settings of the network.
Click Here for more solutions
Nov 03, 2009 | Linksys WRT160N Wireless Router
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Cant connect to internet with emachine through lynksys router.
you will have to add an ethernet card to your emachine if it will take one, or you might be out of luck
Apr 04, 2009 | E-Machines (T2958) PC Desktop
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Have a new imac with leopard and it has a built in airport, how do i get the dlink on my pc to recognise it
To join an AirPort network:
1.
Choose Apple > System Preferences, and then click Network.
2.
Click AirPort in the network connection services list and choose a wireless network from the Network Name pop-up menu. Enter the password for the network if necessary.
If the network you expected is not in the list, it may be a “closed” network and not be available in the list. Try clicking Other, and then enter the network name and password if necessary.
If AirPort isn’t in the list, click Add (+) at the bottom of the list, choose AirPort from the Interface pop-up menu, give the AirPort service a name, and then click Create.
May 08, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Linksys Lynksys Etherfast 16-port Ethernet Switch Ef4116 Ver 2.1 10/100 W/powercord Logo
145 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
