So the tv only works with the DVD player. If I try the cable box, the tv goes to a black screen with sound!
Try puting the the putting the rca wires in to different input out put terminals or leave out yellow rca
Posted on Oct 27, 2012
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 6 Answers
SOURCE: HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Posted on Aug 11, 2008
SOURCE: LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
Posted on Oct 17, 2007
SOURCE: Black Screen
I have a Samsung HP5053 Plasma Flat Screen and there was a cracking noise and the picture clarity changed to dull. Does anyone else have information on recalls for this TV?
Posted on Sep 23, 2008
SOURCE: Westinghouse LVM-37w1
I have had this problem since about superbowl time. If I powered the set off, waited 15-20 seconds, and then powered on, it would work again for a while. Repeating this drill a number of times would lead to stable operation. We resorted to a course of turning on some XM music from DirecTV when we weren't watching. I tried a technician knowledgeable on this set, and it would have cost $500-800 to repair the set. We learned from different forums that the likely culprit was either the power supply board or the LCD controller. We also picked up the rumor that Westinghouse had quit making replacement part. It would seem that the management of this organization has a death wish. TO THE CHASE: shopjimmy.com is now selling parts from canibalized sets. They have a non-DOA warranty and a good return policy. A power supply from "Jimmy" solved my problem. I have one important hint: To remove the back, take out the obvious screws and the base. Then remove the ~5/8" rods that protrude from the bottom. There is a screw up inside each rod.
Posted on Oct 22, 2008
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
Black Screen - No Signal when connect Bluray to TV with HDMI
I just had the same issue and I believe it was because the sound bar was turned off. The solution was turning on all of my connected equipment such as my sound bar, cable box, tv, blu-ray player, and internet router. It stopped "disconnecting" after only 30 secs of being turned on. I think it was because my husband connected it to all those things in some way so the settings are set to work with those pieces of equipment. With one powered off, in my case the sound bar, the signal can't run full circle and reads as if cut off. Please excuse my nontechnical terminology.
Dec 28, 2011 | Philips BDP3000 Blu-Ray Player
I connected my sony DVD player to a 26" sanyo tv. I used the enclosed cable. I plugged the cable in as shown using yellow to video and red and white to audio. Selected video 1 input on tv the DVD...
If you have red, white, and yellow on both DVD and TV it should work. The DVD is obviousy an output so, check your connection on TV. You may find that if you scan through the TV's menu, you will have sound in one arae and picture in another. If you have a DVD in or AUX input on the TV try, and make sure you use the inputs for the respective setting, to hook up there and see what happens. You want input on TV.
Jun 20, 2011 | Sony DVP-SR200P DVD Player
The screen goes black on my lcd but the voulme
Usually a bad AV, Componet or HDMI cable from cable box to TV.
If DVD player or game system works with no issues the Tv is not at fault. (Usually)
If not TV needs service.
Jan 09, 2010 | LG 42LG50 42 in. LCD HDTV
Vcr/dvd player will not let me watch cable through it
There should be video in and video out on the dvd player. You shouldhave the wires going from video out on the cable box to video in on the vcr. Then you should have video out on the vcr going into the tv
Aug 13, 2009 | Samsung DVD-V5500 DVD Player/VCR
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Apr 13, 2009 | Sony BRAVIA KDL-40V3000 Television
TV screen goes Black --- everything else works fine.
cheak cables what are using dvd player thats doing this or all inputs
Feb 06, 2008 | Televison & Video
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
