Question about Car Audio & Video
Air space required for 10 - Car Audio & Video
  • 111 Answers
The air space for each sub is different and most are available from each subwoofer's manufacturer. Try checking their website or call their customer service and they will help.
Posted on Jan 29, 2014
HOW LARG OF A SPACE DO YOU NEED TO RUN A GAS HEATER WITH 200000 BTU FOR FRESH AIR
Will need to be flued or two vents each 250,000 sq mm each one high one low as per regulations
May 18, 2016 | Heating & Cooling
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
Humidity problem 10 ton roof top /fresh air required because of exhaust fans in space.cooling satisfys then building humidity is back.
Do you have a separate make-up air system or is the fresh air the only make-up. You can slow the air speed on the 10 ton by adjusting the motor pulley and give the evaporator coil a better chance to collect humidity. Otherwise add a heavy duty closed loop dehumidifier or more make-up air.
Sep 26, 2013 | Carrier Heating & Cooling
How do you calculate how much free air is required for a 50,000 btu wall heater
Calculate the Cubic Footage of the area to be heated (i,e. Total confined space square footage x ceiling height = Cubic Footage). So let's say the total cubic footage is 3.808. To be considered unconfined space in this example, the total maximum aggregate input rating of all gas-fired appliances installed in the 3,808 cu. ft. space must not exceed 76,160 BTU per hour; (3,808 divided by 50) x 1,000 equals 76,160 BTU per hour.
Normal air infiltration into a confined space will be adequate to supply the necessary fresh air for proper combustion and ventilation if the building is not constructed unusually tight. If it is tightly constructed, some type of fresh air intake should be installed. Being that this 50,000 Btu wall heater is required to be vented to the outside, you can figure that up to 20 to 25% of the heat produced is going up the stack or chimney. That leaves you with a total of 37,500 Btu's dedicated to heating the building.
Placement of the wall heater can be critical in even heat distribution. Of course, it will always be warmer closer to the heater.
I hope this helped answer your question. Thanks for choosing FixYa.
Aug 12, 2011 | Fedders Heating & Cooling
How much space is required for the air pump?
air pumps for bathtubs are anywhere from about 12" long to about 16" and about 10" in diamter
Feb 12, 2011 | Home
This application has failed to start because d3d10.dll was not found. and error 8003002: could not start application sky orb. the requested render path could not be loaded.
Download DirectX 10 and install. SkyORB 3D
  • Operating Systems: Windows Vista, Windows 7
  • Requirements: 29.6MB hard drive space to download, 52.3MB installed; DirectX 10 required (Windows Vista or 7 only); updated graphics drivers recommended
  • Dec 31, 2010 | realtech VR SkyORB 2010
    "10 MB of free space is required" when I have 500 MB space
    connect the usb device to a window os and fix the drive. it should work.
    i presume you plugged out the usb without safely removing the device eh?
    Apr 10, 2010 | Samsung Q1 Ultra MP3 Player
    Car Audio & Video Logo
    16 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
