Question about GE Monogram ZISS480DRSS Stainless Steel
Ge monogram ziss480 how to remove the Dispenser Control Board
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Posted on Jan 21, 2009
VtToolMan
  • 704 Answers
SOURCE: 42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Posted on Jul 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice dispenser will not shut off
If yours has a dispenser control board it would be suspect. Do you know what the model number of your GE is? With that I will be able to trace down all the different possibilities. Most ice makers are mechanical arm up switch is off. let me know, Sea Breeze
Posted on Aug 18, 2009
woodchuck789
  • 4066 Answers
SOURCE: GE monogram 48" side by
Your cold control seems to be bad If it doesn't cut the compressor off as you turn it toward off.
Use your model number HERE to find diagrams and locate your parts.Or post your number back here and I'll look.
Posted on Jan 11, 2011
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
Refrigerator control panel failure, causing dispenser to run for hours, filling refrigerator with burned plastic smell
I have a artic and it has a motherboard in it. This is the most common problem.They are easy to replace and you can get one on the internet pretty cheap.First look at the mobo for any burnt spots on it. If so then get the # off the board and search for it.
Mar 16, 2014 | GE Refrigerators
Water dispenser not working
Then try replacing the dual water control valve. First look around the fresh food section door frame for the model number of your GE Monogram Here is a link to a service manual=> GE Monogram Serevice Manual PDF On page 15 of the service manual explains how to locate and change the water valve=> WR49X10043
I will be here should you have questions, Thanks Sea Breeze
Jan 25, 2013 | GE Monogram Side by Side Refrigerator
Water dispenser wont work -- and ice maker isnt working
I believe your refrigerator is having a control PCB problem. Can you or would you send the model number so I can point out the most likely board or pin plug connection.sea_breeze_8.jpg
Click Here and enter Model number=>
Thanks for any response, Sea Breeze
Dec 05, 2010 | GE Monogram Side by Side Refrigerator
Water in the door not working.Solonoid clicking - filter replaced. Checked the lines. Ice maker works
There may be an issue with the water inlet valve, the dispenser's electronic control board or a dispenser water switch. Contact an appliance service company
Apr 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Unit wont start display only shows (hrs) blinking.only fan in refrigerator area working this is a ge monagram side by side refrigerator. i tried to reset the control butten but display just goes on and...
ok i tapped out and called the repair man. he came and found out the main board is fried.
you have to change the board.
he charged me 350 total for everything.
so all you have to do is order the board and do it yourself.
board is around 200-250 i think
Mar 11, 2009 | GE Monogram ZFSB26DRSS Stainless...
Ice/water dispenser control panel
could be the dispenser board or the main board. hard to sort out without a meter. most likely the dispenser board but i have seen a dispenser board go bad and smoke the main board if that is the case you can damage the new component so check out the cost on the parts
May 07, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS480DRSS Stainless Steel Logo
245 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
