Question about CRC 05528 Air Brake Anti Freeze, 1 gal., Pack of 4
Changed thermostat and resivor tank and still it over heats...Would changing the oil make a difference?...And what could be the problem?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
If you changed the thermostat and res. I'd say your heater-core is clogged or the radiator, or your fans are not turning. Could also be your coolant is to diluted with water as in 70 percent water 30 percent collant.
Posted on Oct 27, 2012
How to change air filter on 2006 Toyota Hiace SLWB diesel automatic?
Hi josephjohn,Here are instructions on How to Change Cabin Air Filter in a Toyota. It is recommended to replace this filter at every oil change.
Jul 29, 2014 | Filter Queen Defender Air Purifier
Engine indicator "ON"
You probably need to reset the indicator. You should be able to find instruction on line how to do this.
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Dec 05, 2013 | Air Purifiers
Where is the thermostat?
a thermostat is always located on top hose from radiator.. just follow ur hose from radiator to engine block when the hose stops then u found it i have not seen a thermostat been any where else, as i been working on cars 9 years ...
Sep 29, 2012 | EBC Brakes 2000 Chrysler Concorde - 3.2L...
Where is thermostat located on 2004 suburban
I'm not an expert but I have changed a few thermostats in my time on different cars and most times the stat is located where the top coolent hose come off the radiator and goes into the engine thats where the thermostat should be and dependeing on the location it should only take about 15 min to change depending on your skill, hopefully that helps you.But if it is behaving like you mentioned it might be your water pump going bad , I just went through a simular problem.
Sep 27, 2012 | Chevrolet 2004 Chevrolet Suburban 1500 LT
I just moved into this mobile home, and the furnace isnt working...the pilot light stays lit, i put it into the "on" position and nothing happened. I went to the thermostat and the switches were in the...
Make sure the filter is clean, then could be a dirty, or faulty thermocouple.If you can ,check the thermocouple,or call 2 or 3 companies to see what they charge to check and clean your unit.
Feb 11, 2010 | Air Purifiers
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
My honeywell air purifier is emmiting an awful
Mine quit too... The led screen went blank so I changed the battery. Now it does nothing. I totally disassembled it as the fan was turning stiffly.(should spin very easilly) The grease in the end bearing was stiff. I washed the gummy grease off the shaft and reoiled with synthetic oil. Your smell is probably motor windings overheating. I disassembled the electronic control and was disgusted to see that there is a glass fuse soldered to the circuit board. I believe the only reason for this fuse is to cause us consumers to needlessly replace otherwise good equipment. (It cost more to pay a repairman to replace the hidden fuse than to purchase a new unit)The fuse is not blown. At least this fuse actually looks lide a fuse unlife the stealth fuses most electronics have hidden in them. I can not obtain a wireing diagram on my 17005 unit but it has a black box inside behind the control panel. It looks like a small start capacitor, but it has a temp rating on it of 70*C. I suspicion it is a single use over heat safety which triggered when my motor got hot due to stiff bearings. I refuse to play their game and purchase a new air cleaner. I love this one... So, if I can not determine what that little black box is, I am going to bypass all the crappy electronics and just drill a hole on top by the handle and install a hi/lo/off manual switch directly to the motors wire hasness. This machine will never give me problems ever again, and if I oil the motor every couple of years with synthetic (Ander oil) this unit WILL last me for the rest of my life...
Oct 26, 2009 | Honeywell 17000 Air Purifier
CRC 05528 Air Brake Anti Freeze, 1 gal., Pack of 4 Logo
41 people viewed this question
Top CRC Air Purifiers Experts
Are you a CRC Air Purifier Expert? Answer questions, earn points and help others
