Question about Garden
My husqvarna mower model loyth2of42t will barely move foward, it goes a little then stops
It starts to go then stops, a little better in reverse
  • george boren Oct 27, 2012
    what kind of ******  hydro or belt driven
SOURCE: Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
  • 95 Answers
SOURCE: craftsman model 917.271814 will not go forward or
Check the drive belt that runs back to the transaxle,it sounds like it broke.If the belt is in the pulley check to see if the transaxle pulley is turning when the clutch is out.Also make sure both wheel axle keys are in the rear wheels.If all this checks out the transaxle may have broke,look underneath to see if it is broken there.
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: I have a cub cadet model 1420 with hydrostatic
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Posted on Sep 28, 2010
  • 130 Answers
SOURCE: i have a Husqvarna Lawn Mower YTH1542XP. when it
It sounds like the transmission drive belt is slipping. When you pull the pedal back you are increasing the tension on the belt. You may also want to make sure the spring that pulls tension on the idler pulley is in tact. Hope this gets you in the right direction.
Posted on Feb 24, 2011
Murrym19546 riding mower want move why?
I would believe the mower is ran off a belt and the belt has stretched to the point and needs replacement. Raise the mower up and look under it and see if the drive belt is sloppy or loose.
May 26, 2017 | Cars & Trucks
MY HUSQVARNA YTH24K48 MOWER WILL BARELY MOVE FORWARD OR REVERSE. I CHECKED THE FREEWHEELING MECHANISM AND IT WAS WORKING PROPERLY. LOOKING UNDER THE MOWER AS WELL AS I COULD, IT SEEMED FINE.
sounds like the drive belt or belts are worn out. replace both in order for it to work properly .replacing one wont work. replace them as a pair.
Nov 05, 2016 | Husqvarna Garden
No foward or reverse
Lock under the mower, is a belt slipping or may has come off a pulley ?
Aug 19, 2016 | Husqvarna Garden
WONT GO FOWARD OR REVERSE
Not sure what all you checked but did you look at your drive belt? If it slipped of the pulley everything will still work just fine but it want move.
Aug 09, 2015 | Husqvarna Garden
Bolens 13ac762f - should this model cut in reverse?
unit cuts forward or reverse better in foward
Sep 11, 2013 | Garden
Husqvarna 42 inch cut with hydrfostatic ****** will barely move in forward or reverse
check the belt tension also if it sounds like a growling sound check the fluid level
Aug 20, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Is there a deck switch on a YTH180
Hi..my name is Keith...and i havent worked on that lawn mower model..so i cant tell you exactly where the safety switch is..but it sounds like the reverse safety switch has failed and the lawn mower thinks you are in reverse..so i would look around your foward-neutral-reverse shifter for it...i hope this has helped..if not write me back
Jun 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Riding mower Safety Tips
Lawn mowers in general can be dangerous, but riding mowers and lawn tractors are even more so. Some models have better safety features than others. You’ll want to look for, at the very least: * A system that prevents the engine from starting unless the blade is disengaged and the machine is in neutral. * An automatic blade shut-off that stops the mowing blades if you stand up rather than sit on the machine, or if you leave the mower/tractor. * A system that stops the blade if you shift into reverse, or at least a lock that requires you to make a deliberate decision to mow in reverse.
Aug 27, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
