My satellite m100 cannot boot up, it keeps rebooting
I'm using Toshiba Satellite M100 model, my laptop cannot start up. It keeps rebooting after flashing of the blue screen. Because it flash too fast, so i couldn't read the error on blue screen. I search on internet that they asked for changing the SATA mode to ATA instead of AHCI, but i couldn't find the way to change this setup. Please advise me, your comment is highly appreciated. Thanks.
  • joecoolvette
    joecoolvette Oct 28, 2012
    I want to know; 1) Has the laptop ever been cleaned inside? Taken apart, and cleaned? Was the Thermal Pad removed, parts cleaned, and new, fresh Thermal Paste applied? 2) Are there bad Electrolytic Capacitors on the motherboard? I go with hardware failure. It often emulates software problems, and confuses the h3ll out of 'techs'. (Ha) Post back in a Comment. A)http://capacitorlab.com/visible-failures... B)http://www.irisvista.com/tech/laptops/To...
5 Suggested Answers
TampaNative
  • 778 Answers
SOURCE: toshiba satellite m100-jg2
Alf, you are asking about multiple issues with different computers in the same thread and also requesting off Forum help via email. This is just confusing and I don't see any way to help you other than pointing this out.
Good luck.
Posted on Feb 24, 2008
ibleedblue18
  • 50 Answers
SOURCE: Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Posted on Dec 07, 2008
durtopian
  • 408 Answers
SOURCE: i need a infrared driver and a blue tooth driver
(http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1277462&rpn=PSMA0U&modelFilter=M100&selCategory=3&selFamily=1073768663).....................PUT THIS IN YOUR BROWSER AND SELECT WHAT OPERATING SYSTEM YOU HAVE.THERE IS THE DRIVERS YOU NEED.
Posted on Aug 10, 2009
  • 2678 Answers
SOURCE: i have toshiba satellite L505-S5990
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Posted on Aug 30, 2010
When i turn onToshiba Satellite M100-JG2, get black screen,and hear 2 bee sounds,computer won't start.
Two beeps a generally a memory parity error.
Use a test utility like memtest86 to check it. Youll need another computer with a CDRW to create a test disk from an ISO.
Then boot the computer with the cd in and it should run from CD.
Memtest86 Advanced Memory Diagnostic Tool
Jul 02, 2014 | Toshiba Satellite M100 Notebook
Bios password for toshiba satellite M100
You can reset the BIOS password. To do that read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Apr 28, 2011 | Toshiba Satellite M100 Notebook
My toshiba satellite M100 keep turn off, why?
I use a Satellite. They are not heat friendly. Use canned air to blow out the vents on the side & back and blow out the fans on the bottom. Get a cooling fan for under the computer. Try to use it on a firm or hard surface since a soft surface won't allow air flow. Blow it out at least every 2 weeks.
Sep 30, 2009 | Toshiba Satellite M100 Notebook
How to format a Toshiba M100
get a win 98 boot disk floppy. set bios to read floppy or usb floppy first save and exit. insert disk and boot comp. select boot without cd rom support. At command prompt type " FDISK " then hit enter dont type quotes. delete the particians then create new partician set 1 particians as active then remove disk then insert OS disk and go forth. I after you install your new OS and you get two boot options at the command promt after loading type " delpart " and delete the particians and save (use the tab and alt keys to bring up menus save and exit before you leave delpart) reboot and run fdisk to creat a partician and set it as active. then load your OS
Jun 10, 2009 | Toshiba Satellite M100 Notebook
When i start-up my toshiba satellite m100 it ask to insert media
try to remove the media player form the.. system, sturt up..
Go to start, run, type msconfig then enter, then remove sturt up then ok
Jun 07, 2009 | Toshiba Satellite M100 Notebook
ATI DRIVER FOR TOSHIBA SATELLITE M100
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 21, 2009 | Toshiba Satellite M100 Notebook
You should upgrade your RAM memory. Check with the owners manual and purchase RAM module. Install the RAM module in the memory slot provided at the bottom of your laptop.
http://www.notebookreview.com/assets/11050.jpg
You should also check the speed of the internet connection you use.
May 13, 2008 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
