Question about Admiral AED4475TQ
My admiral dryer model AED4475TQ belt came off and the pulley is laying lose I need a diagram to fix it please help
Need diagram to belt and pulley back on
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Hopefully this helps! My drawing isn't great or good for that matter. The washer has a place to insert the pulley in front of the motor. Put the belt around the drum. Then push the pulley back away from the drum and insert the belt in between the forks and then wrap it around the pulley of the motor. I really hope this helps.
my admiral dryer model AED4475TQ belt came off and - 10_27_2012_1_40_05_am.jpg
Posted on Oct 27, 2012
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
Going from a 3 prong to a 4 prong dryer plug
Admiral AED4475TQ is an electric dryer? Was your old dryer gas? If so, you need a 220 line installed to run the electric dryer. Here is a link to instructions from ehow http://www.ehow.com/how_5824435_wire-220-plug.html.
Jan 13, 2013 | Admiral AED4475TQ
I'm trying to install a 4-wire system electrical
Hi heathvaneato...
Go to the following webpage and you will see a picture and description of how to wire your dryer.
Please take time to rate me thumbs up.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.ph
Sep 23, 2011 | Admiral AED4475TQ
Need help putting new belt back on Admiral dryer model ADG 7005 AWW, possibly a diagram?
Hi bgpace02669..
To to this webpage to see a picture of how to route your belt.
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 09, 2011 | Maytag ADG7005AWW Gas Dryer
The pulley and brcket fell off it's position laying in the bottom of the dryer don't know how it goes ?
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belts. A replacement pulley can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number is 691366 (if needed).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Whirlpool Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 | Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
Whirlpool model WGD5300SQ dryer belt is off, roller is laying loose, is there a diagram?
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 18, 2009 | Dryers
My dryer belt broke
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. There are numerous dryer belt diagram illustrations listed that you can print out. Admiral is listed. I hope this helps you.
Nov 12, 2008 | Roper REX3614KW Electric Dryer
Admiral AED4475TQ Logo
207 people viewed this question
Top Admiral Dryers Experts
Timllfixit
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
