Question about Kenmore 400 6943 Dryer
Heat eliminte come on when turning the timer on and before turning on
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
The heating element could be grounded. I would unplug the dryer and inspect the element to see if its touching metal.
Posted on Oct 27, 2012
Testimonial: "George Thank you for your help. You where correct . After looking into more I found one of the ceramic brackets broke and the element sticking against the metal. Thanks again, Rick"
  • Richard Wheeker Oct 27, 2012
    it wasn't doing this before. I had to install a High temp thermostat in because the motor wood not come on ??
  •  George Michael Smith
    George Michael Smith Oct 27, 2012
    The temperature thermastat prevents the drier from getting to hot. Im still leaning towards a grounded element.
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Heater eliminte comes on when you turn the timer and before turning on the dryer unit ??
The heating element coil is most likely touching the grounded metal enclosure and running on 120 volts. It's a potentially dangerous situation! You will need to replace the coil ASAP.
Oct 27, 2012 | Kenmore 400 6943 Dryer
I changed the elimint and still no heat what els could be wrong
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 09, 2011 | Kenmore 62602 Electric Dryer
While playing a game we lost video but not audeo. Same on either tv.
If you mean to say that you HAVE audio but DO NOT have video. IF IT IS UNDER WARRANTY SEND IT IN!
This is a common problem with XBOX 360 and you can repair it by doing an xclamp replacement or by removing the xclamps, tighten all nuts on the heat-sync and applying new thermal paste etc., and replacing teh xclamps. Your choice and there are plenty of videos online to show you how.
FYI- use nylon washers on ther board and DO NOT use ceramic based thermal paste, use a "silver based" for high heat. Also, locking washers instead of the standard metal you'll see in most vids keep teh heat-sync from getting loose down the road. just make sure they are 1mm or 1/32 thick, and watch multiple videos before you choose one to follow. This helps to elimintate poster's "guess work"
May 13, 2010 | Microsoft Xbox 360 Console
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Not heating/timer knob not turning . the dryer works but is not heating and i noticed that the knob is not turning therefore it does not shut off just keeps running.
HI. The timer device is responsible for initiating the heating cycle. If the dial plate is unable to advance, the heating circuit will not operate correctly, thus, preventing proper heating. Another indication of timer mechanism failure will be an un going cycle. You have stated that the unit Will continue to run, without stopping. This is caused by the defective timer device.
In most cases, the actual timer motor will Fail. This motor is , essentially, responsible for the forward motion of the dial plate.
I recommend to replace this damaged timer device, asap.
Jan 19, 2010 | Whirlpool Dryers
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
Dryer not heating up
If the timer knob does not turn in a clockwise direction, then chances are the timer is bad.
Heating is a different issue, although, if the timer knob will not turn, then it may not be at a position that turns the heat on.
Replace the timer, then check the heating. If the heater then works, then the problem was in the timer. If it doesn't, then we need to look at problems within the heater circuit.
Reply back what you find out.
Jan 23, 2009 | Whirlpool LER5636P Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Kenmore 400 6943 Dryer Logo
309 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
