Question about Kenmore 400 6943 Dryer
Heater eliminte comes on when you turn the timer and before turning on the dryer unit ??
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The heating element coil is most likely touching the grounded metal enclosure and running on 120 volts. It's a potentially dangerous situation! You will need to replace the coil ASAP.
Posted on Oct 27, 2012
2 Suggested Answers
SOURCE: heat eliminte come on when turning the timer on and before turning on
The heating element could be grounded. I would unplug the dryer and inspect the element to see if its touching metal.
Testimonial: "George Thank you for your help. You where correct . After looking into more I found one of the ceramic brackets broke and the element sticking against the metal. Thanks again, Rick"
Dryer admiral aed4475tq1
Check heater element itself may have a short to casing seen this many times bra wire most comon cause stuck in heater
This dryer is a whirlpool disgn
Heater coil may be shorted to case
Dec 05, 2013 | Dryers
Heat eliminte come on when turning the timer on and before turning on
Oct 27, 2012 | Kenmore 400 6943 Dryer
Indesit G74V dryer not spinning
sounds like you have a heater that is shorted to ground which will cause the unit continouoly heat but will not allow unit to start, in addition you may have a bad push to start switch or bad mtr centrifical switch. Best advice is to unplug until a tech can look at it or by a new one
Apr 16, 2012 | Dryers
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
Not getting hot
Lets look close at that heater assembly: whirlpool%20dryer%20element.jpgThe small limit on the top(300F) will blow if the duct is stopped upThe bottom fuse is its cousin(250F), they are partners in crime. When one fails both are bad and both come in a kit. The dryer If you have power to the unit and all of the various safety's andelement is checking out ok, then you need to check the timer. The largered wire going into the timer is the weakest point, it draws atremendous amount of current from the heater element and is the mostfrequent failure point in the timer. Remove the large red wire on theterminal marked RH on the timer. Slowly turn the timer and check forcontinuity between the RH terminal and every terminal on the timer. Ifyou cannot get a continuity reading at any point in any cycle, then thecontact inside the timer is burned up. Timer replacement will benessesary. Here is a burnt contact: burnt%20dryer%20timer.jpg?height=235&width=420
Click on pic to enlarge
Sometimes you can file that contact down and go some more. This one looks fileable.I have seen em burnt slap up nothing left to file down.
Oct 22, 2009 | Kenmore Dryers
Freezer is covered with frost, I defrost it with a hair dryer and the next day it is back to the same as it was before
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | Freezers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer not heating up
If the timer knob does not turn in a clockwise direction, then chances are the timer is bad.
Heating is a different issue, although, if the timer knob will not turn, then it may not be at a position that turns the heat on.
Replace the timer, then check the heating. If the heater then works, then the problem was in the timer. If it doesn't, then we need to look at problems within the heater circuit.
Reply back what you find out.
Jan 23, 2009 | Whirlpool LER5636P Electric Dryer
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Kenmore 400 6943 Dryer Logo
98 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
