Question about GPS
Need a furuno 1721 signal cable
Furuno part no 008-428-560
Furuno 1731 radar i purchased, the person i got it from extracted the pins from the plugs on the signal cables 3 plugs. all pins are still on the wires i just need the pinout to reassemble the plugs
Your only option here would be to contact Furuno support and talk to a tech from the people that actually designed and built the unit.
Furuno support can be contacted at:
http://www.furunousa.com/Support/FAQ.aspx
Should anyone require the owner's manual it is accessible at the link below.
Hope this helps.
-Steve
http://www.furunousa.com/ProductDocuments/1731%20OME.pdf
Apr 10, 2015 | Furuno Boating
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Need a schematic for a Furuno 1621 Mark-2 radar
Hi Bruce
It has been my experience that Furuno doesn't part with their schematics cheaply. If you contact their support department, they MIGHT sell you a schematic, going price is usually about $100. Here's a link to their support/forum page.
Good luck.
-Steve
http://www.furunousa.com/Support/default.aspx
Dec 29, 2014 | Furuno 1623 Radar 16nm Range
Radar furuno 1721 mark-2
Must have RSB number and FCC ID number
Nov 09, 2013 | Furuno 2.2kw 18" Radome
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
Ca I buy a 5 metre extension cable as the 10 metre cable that came with the 1623 is too short?
Quite sorry but Furuno does not carry "extension" cables for radar antenna signal cables. If the original cable is too short, you would need to obtain a 15M whole cable, furuno part number 001-122-870-10. Or the 20M whole cable part number 000-144-565. You might be able to find a technician willing to custom manufacture an extension for you but I emphasize the word might.
Regards,
John
Feb 18, 2012 | Furuno 1623 Radar 16nm Range
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
GPS Logo
49 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
