Question about Dodge Vehicle Parts & Accessories
Heater in my 2003 dodge ram quadcab not heating
When i turn my cooling dial to red(heat), I just get cool air. Can someone help me troubleshoot and fix this?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Could be the heater core went bad, heather core lines are plugged, cover one the blower motor is off, or if your temp selector is cable, the cable may have seized
Posted on Oct 28, 2012
3 Suggested Answers
  • 12 Answers
SOURCE: no response for heating or
It could be a bad blower motor or blower motor resistor.
Posted on May 18, 2011
  • 81 Answers
SOURCE: I have a 2007 HHR.
need to have the freon checked. keep an eye out for places that offer a free a/c check
Posted on May 28, 2011
I have a 2003 dodge ram truck.. my problem is the heat/cool selector does not switch over. have cold air year round. everything has been replaced excepts this switch.. so how do I fix this
you gonna have to find the switch and check the wires are connected, if they are connected then it could be a fuse or a relay switch my be bad. there could also be a short or ground somewhere and wire tracing can be annoying
Sep 23, 2014 | 2003 Dodge Ram Pickup 1500
I have a 2003 dodge ram 2500 and i replaced the recir. door and the upper blend door and i still have very little heat inside. the heater core is clear, not cloged
check that the heater control is working and allowing water through the heater . Check that there is not an air lock in the cooling system that is preventing coolant flowing through the system.
Aug 09, 2014 | 2003 Dodge Ram Pickup 2500
Heat doesn't blow out on the driver side only cool air. On a 2003 dodge ram 1500 pickup.
Check your coolant level. If it's low it'll not get to the heater core.
GL,
Td
Oct 17, 2012 | Cars & Trucks
Heater in 2003 Dodge Ram 1500 blow cold air out of vents on driver side and warm air on passenger side when turned to heat.What could be possible cause?
Not sure about your dodge, but on hondas there is a lever under the driver side vent to allow fresh(outside air) when its cold out, it will be cold, even with the heat on inside, so check to see if your has that lever somewhere on that side...hope that helps
Jan 02, 2011 | 2003 Dodge Ram Maxi
I have no heat in my 2003 Mitsubishi Lancer. When
The cable that pulls the cool/heat switch on the a/c gets weak and it doesnt allow the dial to switch over to heat. You can see that cable and the way its supposed to work on the right side of the gas pedal over it. I usually just use my foot to push that switch over to heat and reach with and pull on it with my right hand to cool.
Jan 08, 2010 | 2003 Mitsubishi Lancer
The heater in my 2003 Dodge Ram 4x4 will not heat up or gets only luke warm & only on the passenger side....any suggestions?
Cold on drivers side and heat on passengers side, actuators working properly and blend doors are moving. Heatertreater is for piece of plastic on actuator motor. I moved blend door by hand after disconnecting actuator and works fine, both sides freezing when moved in opposite direction.
Dec 04, 2009 | 2004 Dodge Ram 1500
My 2003 dodge ram 1500 truck stopped heating. Cool air is all that comes out.
low radiator coolant level OR bad thermostat and Lord I hope not,a leaky heater core.Check fluid level first the look at thermostat replacement only after the level check. Good luck and bless you in advance if you should catch a cold...from the cold!
Nov 02, 2009 | 2003 Dodge Ram Maxi
Luke warm heat
You may need to replace your thermostat. Also while you are at it flush and fill your cooling system.
Oct 15, 2009 | 2004 Dodge Ram 1500
2003 Dodge Ram Van 1500 *** NO HEAT **
Do you have enough antifeeze in your cooling system. If not fill & check again for heat. You may have a blockage. If so remove the in & out hoses to the heater core on firewall. Be careful not to damage core. Use a garden hose to flush the core one side to the other untill running clear water. put one hose on tight & clamp, put other on loose. Have someone start engine & slowly remove loose hose to let air escape. when fluid appears put hose on & tighten. Refill rad & resevoir. Heat engine up & check for heat. Also heat cable may be off under dash.
Sep 12, 2009 | Dodge Ram 1500 Cars & Trucks
Vehicle Parts & Accessories Logo
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
