Question about Samsung WF337AA Front Load Washer
Be2 error on samsung front loader - Samsung WF337AA Front Load Washer
2 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
Samsung washer spinner is not spinning
Model number? Top loader? Front loader? Any error messages? Is it doing anything else or is it just dead?
Nov 13, 2016 | Samsung Washing Machines
My washing machine won't spin and nothing will work for it, could I get some help.please
What is the make and model of your washer?
If it's a Samsung, the bE2 code means that there is an error with one of the control panel buttons.
Try this: Disconnect appliance from mains power and clean the buttons with a lightly dampened cloth.
Plug appliance back in to power after cleaning buttons.
If problem persists: Press & hold the button for 1 minute.
It's possible that the button switch has worn out and will need replacement.
Jun 08, 2016 | Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
My front loader washing machine samsung has an error SE. What does this mean.
Contact supplier and ask them the question.to get the right answer.
Jan 09, 2015 | Samsung WF337AA Front Load Washer
Error code be2
www.samsung.com/Dishwasher
May 23, 2014 | Samsung Dishwashers
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
What does be2 mean on a samsung front load dryer?
You have a bad board. I recommended that you have professional come and replace. You are looking at about $125 or so to fix it.
Apr 30, 2011 | Samsung Dryers
Samsung WF337AA Front Load Washer Logo
1,055 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
