Question about Philips 22pfl4505d/f7 22-inch 720p Led Lcd Hdtv, Black
TV died this TV is 1 1/2 years old and it completely stopped working, no sound no picture, out of the blue. Cable guy came over and said it is the TV, not a cable issue.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Main board problem , please replace the specific main board .
Posted on Aug 27, 2013
SOURCE: Television has sound but no picture
You can try unplugging the tv and wait for a couple minutes and then plug it back in... I just did this and now the television works again.
Posted on Jan 31, 2009
SOURCE: Black screen with sound. Problem on every channel.
Sound no picture or shut down Power led starts green then a short amber then turns RED . If your power supply can be confirmed to be go you have a bad Inverter board. Per the manufacture this part comes only with the panel . Not cost effective . But if you go to
lcdparts.net you will locate an inverter for $ 169.99 . I had the same problem and the inverter repaired the set . Note there are similar error codes but from what I can see from all of your complaint I do be leave that your Inverter is bad . Good luk
Chongo
Posted on May 16, 2009
  • 7 Answers
SOURCE: it keeps loosing the picture
try going into the menu options try the auto tune for HD channels. (If available use the AFC node). There should be something like level 1-2 etc... which is like a factory reset program.This works for some CRT monitors not really certain but may also be common in LCD as well as Mercury assisted lighting in the HD monitors. Hope this helps Good luck I imagine the repairs can be costly
Posted on Aug 15, 2009
bluenadas
  • 203 Answers
SOURCE: Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Posted on Sep 27, 2009
  • 8457 Answers
SOURCE: TV wont power on but green light indicates power on
No,it ur backlihght video inverter board is dead,need a new board.
Posted on Sep 29, 2009
TV taken a long time to come on
sound but no picture blue light is on - already had cable out said its the tv - its only 4 years old . it worked the night before.
Oct 08, 2012 | LG 42LC2D 42 in. LCD HDTV
Sony KD-36XS955 36 inch wega televison has yellow caste, cannot adjust to get any blue color. Has same problem on both cable and Directv. Unit is about 3 years old.
It is one of two issues, the blue video driver is defective, or the blue gun in the picture tube is open. This will need a tv tech to varify the problem and suggest a course of action.
Feb 13, 2011 | Sony FD Trinitron KD-36XS955 36" TV
No picture or sound!!
Call the tv warrenty serviced repair,tv under a one old right?The tv power supply board is dead,need repairing by replacing power supply parts call like capacitors common parts dies by leaking gases in the power supply board.
Jul 07, 2010 | JVC LT-40X776 40 in. LCD HDTV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Tv turns it self off,has no sound w/ out HDMI cable
We have cable from ETEX and yesterday out of the blue my sound went completely off! I don't know what caused it and it is not muted. How do I get sound back?
Nov 10, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
TV lost it's picture...Only have sound
Need more info.
Is blue screen on all inputs, conponent, composit, HDMI, tuner... ect
Do you have MENU is it in color?.
Email me.
Jan 09, 2009 | Samsung Televison & Video
Zenith E44W46 Audio works - intermittant picture
i hava a Zenith Model # E44W46LCD telivision. There is a light blue line about an inch or 2 wide running across the bottom of the screen. The TV is about 4 years old. It doesn't get a lot of play probably less than 10 hours a week. can you help me
Jul 18, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony KV27v15 DOA
The high voltage circuit also runs the horizontal deflection circuit and much of the rest as well. The horizontal problems you describe were a prelude to high voltage failure. If the TV is anywhere near 10 years old (how come you guys never give the age????) it isn't worth the cost of overhauling the high voltage circuit. You might be able to replace just the H.O.T. but the flyback is the source of the failure.
Jan 09, 2008 | Televison & Video
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Philips 22pfl4505d/f7 22-inch 720p Led Lcd Hdtv, Black Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
