Question about Whirlpool LER7646J Dryer
Dryer takes twice as long to dry clothes.
Dryer produces heat and air flows freely from exhaust vent, only the dryer takes at least twice as long to dry a load of laundry.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Did you check the outside vent? Those get clogged as well.
Posted on Oct 27, 2012
SOURCE: Brand new electric dryer suddenly does not dry well
my dryer does the same thing.
sounds like your dryer's exhaust needs to be cleaned as it is full of lint - the part that connects from the dryer to the wall and also inside of the wall. For Inside of the wall I usually take a fish tape .
also.... i would look at returning the dryer if it is not trapping the lint. i would return mine but it's out of warranty...
Posted on Jan 27, 2008
Illeagle
  • 525 Answers
SOURCE: I Have a Whirlpool LGR6620PQ0
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_16
You may have faulty gas valve solenoids, especially since you've already replaced the other ignition components. Below is an image, (I hope), of the solenoids which can be found and ordered from the link above. A more rare cause can be a lint filter obstruction, i.e. the screen can be coated with an invisible film from using fabric softener sheets. Try running water over the filter screen, horizontally, and if water does not strain through, then replace the filter and stop using fabric sheets.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
dragonsthatk
  • 547 Answers
SOURCE: My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Posted on Feb 11, 2009
  • 291 Answers
SOURCE: wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Posted on Dec 30, 2009
SOURCE: Dryer heats up but clothes won't dry
I have an amana electric dryer. Changed out thermal fuse and cleaned out vent. Thermal fuse is blown again, but I noticed that it is not cycling. The dryer is very hot on the outside on top.
Posted on Sep 11, 2011
My whirlpool dryer model ler3624jq1 type d433-ele-2406028-fm54 isnt drying my clothes completely
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 17, 2012 | Dryers
Dry takes a long time to dry cloths
May 28, 2012 | Kenmore Dryers
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
I have a maytag dryer DE882. The dryer blows warm air but does not dry clothes. Any ideas what could be the problem.
May 18, 2012 | Maytag Dryers
Kenmore dryer model #110.62612101
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes;
May 17, 2012 | Kenmore 74112 Gas Dryer
Indesit IS70C tumble dryer not heating
May 10, 2012 | Indesit IS70C Electric Dryer
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Dryers Logo
165 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
