How can I connect my ps3 to a konka tv? Is there an specific channel that I have to tune? I tried AV1 Av1 and it doesn't work?
    Genius:
  • Televison & ... Master
  • 2,432 Answers
If the output wire from the ps3 is an rca type, you can hooked up only to the component input like the av1, av2 or av3.
Posted on Oct 27, 2012
SOURCE: no sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
  • 244 Answers
SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Posted on Nov 26, 2007
  • 121 Answers
SOURCE: when we plug anything into the av1 we loose colour
Check to see if the cable is properly connected. Both on the TV, Video and DVD points. If it's a SCART, does it have a small switch on it? Also check settings to see of there might be a PAL/NTSC issue.
SOURCE: How to make AV1 input the default when switching
Thanks. Problem solved. I found the operating instructions and read them!!
M.J. Ramage
Posted on Sep 10, 2009
SOURCE: on a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Posted on Oct 31, 2009
HI I AM TRYING TO TUNE MY VIDEO INTO AV1 BUT NOT WORKING CAN YOU HELP
hi scart lead from av1 on the vcr to av1 on the tv ,press source on the remote or input it should automatically find av1 thanks
shaun
Jun 28, 2017 | Televison & Video
Can only get av1 and av2 when trying to tune lg v271 video recoder
What kind of wire are you connecting to the antenna jack> Cable or antenna? When you do a tuner setup you have to select which one you will use before doing a channel scan
Aug 22, 2016 | LG V271 DVD Player/VCR
I have recently bought a sony bravia model number KDL-40EX710. The input channel either keeps flicking to another input channel, ie AV1 to HDML or when on AV1 or AV2 the channel confirms itself at the top...
Your connections might be loose and the tv is constantly recognizing the connection over and over, that would explain the pop up. I would imagine the picture would be distorted somehow if that was the case but worth a try. If the problem persists after trying a good new cable then I would call the manufacture.
Aug 24, 2011 | Televison & Video
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
How do I tune this TV to my sky box Technika lcd19-907 hd tv
you shouldn't have to tune the tv, simply plug 1 end of the yellow RCA lead into the yellow AV1 input usually located at the rear of the TV, & plug the other end into the TV output located at the rear of the my sky box. Then select AV1 on your tv. Or better still if you have the HD cable plug it in & select HD channel on your tv no tuning necessary
Mar 12, 2010 | Televison & Video
Samsung Exit TTX mode
Had to reset the TV and re-tune all channels. But it worked.
Feb 02, 2010 | Samsung DynaFlat TX-P3064W 30" TV
New tv but can not get any signals, have checked all conections
After about three hours I got my old T V out and connected it back up, Ha same problem then I realised as we have cable which goes through the decoder which was connected to AV1`.
Set new T V to AV1 and whamo I had a picture and everything is working fine.
Dec 10, 2009 | Konka Televison & Video
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
RECENTY PURCHASED SECOND HAND TV WITHOUT REMOTE OR HANDBOOK CANNOT SEEM TO SET UP MY SKY BOX TO IT ANY SUGGESTIONS?
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Oct 22, 2008 | Televison & Video
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
