REAR PROJECTION 55IN MITUBISIHI TURNED ON AND EVERYTHING IS BLUE
NOT SURE WHAT TO ADD
  • 8,617 Answers
If you see curved blue lines its a bad CRT. If its a solid blue without any picture or sound its most likely a signal issue
Posted on Oct 27, 2012
  • 5 Answers
SOURCE: toshiba 42PW33Q rear projection gone blue
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: Philips 55pw9363/17w Flasing Power Button
check for bulb replacement
Posted on Jun 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: Toshiba tp5581a 55 in. rear projection tv.....problem
the yokes need adjusting (upside down writting) and the CRTs need alignment
Posted on Sep 11, 2008
barbu51
  • 566 Answers
SOURCE: Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Posted on Dec 07, 2009
  • 5 Answers
SOURCE: I did the self check on my Mitsubishi 55in Television
IC possibly getting hot and might soon go out. 1 blink then 2 blinks is operating normal
Posted on Jan 10, 2010
Got the TV 4 free so lets start at that. Was a very poor picture so checked the guns saw the green/blue was very foggy and changed the CRT Fluid in Green and blue red obviously was fine. Now tv up and...
are the lines slightly curved and go from the botom to top across the screen. If so it sounds like retrace lines from the CRTs being turned up too far. You can add the pic by clicking the camera Icon next to where it says Insert below the text box.
Nov 03, 2011 | Philips 50P8341 50" Rear Projection...
Need a screen for my 55in
I believe Mitsubishi would be the best source for the screen.
The Diamond Shield is part number 760D639020: $77.90.
But make sure the fresnel lens and everything else is in good shape first.
Sep 11, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Jan 07, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Green and pink shadow on my samsung 55in proj tv what can i do to fix it. i all ready fixed red and blue line but green is way off and i dont see any way to fix it
hi, this is the early signs of convergence board chip failure. you will need to replace this board in order to correct the collaboration feature. the convergence is responsible for regulating the RGB stream in you set. if it is malfunctioning, you will not be able to regulate the red blue green streams.
May 16, 2009 | Samsung HCL5515W 55" Rear Projection...
Blue spot and burned images on my hitachi 55vs69.
Bad Light Engine Call UED 1-800-648-6657 ask for rebuilt.
Dec 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
HELP ME
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2008 | Akai PT5492S 54" Rear Projection...
Sep 11, 2008 | Toshiba 50H81 50" Rear Projection...
Sony with blue screen
make sure you are on tv slection and not video1 ,aux . pull up menu go to setup look for cable/air make sure you are in tv mode not video aux.if this does not fix it then you may have bad tuner.
Jan 13, 2008 | Sony KP-43HT20 43" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
