Question about RCA L37WD12 37 in. LCD HDTV
Rca 46 inch lcd tv, no sound
I have a rca 46 inch lcd the picture went out and it was saying unusable signal,so i got a hdmi box. i got a picture now,but no sound.can you help?
  • Anonymous Mar 14, 2014
    46 inch 3 d
  • 8,596 Answers
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
My dell w3201c tv displays "no video signal" when i power it on
Coaxial cable does not carry video signals but rather rf-signals
To use coax you will have to tune like you are searching for a signal from your aerial..
If you prefer to use video then you will have to use a video cable either rca or hdmi. you can then choose video or hdmi from the remote
Len
Sep 12, 2014 | Dell 221-9703 W3201C 32 INCH LCD TV...
Sound and rca jacks not working on rca 46 inch lcd tv
check ur set up find manual if no go .go to there web site
Aug 12, 2012 | Televison & Video
My RCA L46WD22 TV turns on but there is no picture or sound, just "unusable signal" message.
This is a very common problem with these models.
The problem is a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Jul 21, 2010 | RCA L46WD22 Television
42 inch rca lcd tv says unusable signal
The problem is very likely a fuse that has blown, if the following is true:
No Audio at all.
Jul 20, 2010 | RCA L46WD22 Television
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
RCA 46" LCD TV - HDMI Stopped working overnight
I don't mean to sound ignorant, but can I assume you have already checked your Source Selection just incase someone hit a different button on shutdown ?
Sometimes when I just set the remote down can sometimes change a setting on the TV, I thought maybe the same may have happened to you too.
Jun 03, 2017 | Televison & Video
Unusable signal
it was a fuse in the digital board i took it to an rca repair shop and had it fixed has been working great since
Sep 25, 2008 | RCA L46WD250 46 in. LCD HDTV
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
Help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
May 31, 2008 | RCA L42WD250 42 in. LCD HDTV
RCA L37WD12 37 in. LCD HDTV Logo
1,384 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
