E10 error with my Electrolux EWF1083. Checked hoses - no kinks, checked filter - all clear, have noticed however when the machine fills with water I pull out the soap tray and see that the water is going into the prewash trough rather than the centre one and during the rinse cycle water that should be going into the fabric softner trough is in fact going into the centre soap powder dispender. Sounds like a programing issue?
  • John Holland Oct 28, 2012
    Thanks Richard, as mentioned in my post I have checked all the hoses both inlet and outlet and all are free of kinks. Filter is all clear. Washing machine fills up as required on wash and rinse cycles however on at least 2 occasions during the full cycle E10 appears and by pressing the start button it resumes as normal. What I can't figure out is why on fill up water goes into the pre-wash trough leaving the soap in the middle trough. Also when the fabric softener is required water flows into the centre soap trough and not into the softner trough. It seems that the water flow in to soap troughs has gone one row over to the left.
I tried suggested answers around the internet (check hose, cleaning filters, etc. Nothing worked). What fixed the problem (at least temporaly) was to unplug the artifact, plug again, turn it off and then reset the program. This made the water valves make a "clack" sound and start working again (I could hear the water coming in).
Posted on Oct 04, 2015
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
E10 is a timeout code. Check the water supply lines for a kink or a clogged filter.
Posted on Oct 27, 2012
5 Suggested Answers
  • 193 Answers
SOURCE: I frequently get an E10 error code when the
E10 is a water filling problem.In reviewing your comments,I would suggest flushing the line going to the machine
Posted on Nov 10, 2009
beltronic205
  • 1467 Answers
SOURCE: my machine won't take the fabric conditioner. It
ok try removing the soap tray and cleaning. it works by filling to a certain level then allows to empty by way of Syphon effect, you can check this easy with a glass of water fill it as far can go does it drain away? It should , if it does then try with softner on wash should now be ok, providing The valve coils are okay..you can let me know.
Posted on Jun 24, 2010
SOURCE: Low cold water pressure. The inlet light flashes
I am having the same problem. Did anyone ever resolve this issue?
Posted on Apr 12, 2011
  • 6277 Answers
SOURCE: HOTPOINT ULTIMA WD71..WHEN THE MACHINE
Following is pre-typed, saves time - in your case just refer to 'cold' please ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Jul 16, 2011
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
E10 code on a affinity
Hi James, thank you for allowing me to assist you!
If you are receiving an error code E10, it typically indicates that your washer machine is taking a long time to fill (or is continuing to fill). Here are a few simple troubleshooting tips that may help you resolve this issue:
·Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your appliance. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Best regards!
Feb 04, 2014 | Frigidaire Washing Machines
E1
Good Morning shannon galway - Could the unit possibly be experiencing an E10 or E11 and not displaying all of the numbers correct? If so, both error codes indicates that the water is taking too long to fill.
Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
However, if you are not experiencing either of these two error codes, is your unit an international model? If so, this could mean something completely different, which I would personally suggest reaching out to the manufacturer directly for further assistance.
Apr 23, 2013 | Electrolux Washing Machines
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
May 19, 2010 | Washing Machines
E10 & E20 problem
e10 problems refer to water supply..so check the tap is on, the inlet hose is not kinkrd, and the filter in the inlet hose is not blocked.  e20 refers towater drainage,  so check the drain hose isn't kinked and the drain pump isn't clogged
Aug 09, 2009 | Electrolux EW1000i Front Load Washer
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
885 people viewed this question
Top Washing Machines Experts
