Question about Maytag SDG3606A Gas Dryer
How do i change the ignition coil set (gas value coils) in my maytag dryer? part #279834
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Http://www.youtube.com/watch?v=KMkvy1RibZw&noredirect=1
The link above should help.
Posted on Oct 27, 2012
  • 177 Answers
SOURCE: Maytag com dryer Model #MDE16PRAYW Setting coin Value
Unplug the unit, open the control panel, look for the instructions inside the control panel. program as needed. you will need access to coin vault and meter case.
Posted on Jun 07, 2008
garing
  • 998 Answers
SOURCE: Maytag MDG5500AWW gas dryer with inconsistent flame
the booster coil gets hot and stops working just replace all three and give me thumbs up...i get$60 for a house call
Posted on Aug 08, 2009
  • 2468 Answers
SOURCE: gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
Posted on May 04, 2010
  • 3074 Answers
SOURCE: My Maytag gas dryer SDG515DAWW won't heat. What I
http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Nov 06, 2010
Testimonial: "The link was helpful. Thx"
richroth
  • 9472 Answers
SOURCE: pyg2300aww maytag dryer, is not heating I changed
The problem must be in the igniter then if you replaced the coils. Here is a link to the part you need.
http://www.appliancepartspros.com/part_details.aspx?part_id=4038992
Posted on Nov 23, 2010
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Maytag atlantis gas dyer not heating
Can you look inside the door for your model number. I believe the problem is either a defective igniter or defective solenoid coils that open the gas valves=> 279834 Gas Valve Solenoid Set
4391996 Dryer-Igniter
Here is a Manual=> Atlantis_Neptune_Electric_and_Gas_Dryer_Service_Manual
I will be here if you have questions, Thanks Sea Breeze
Feb 28, 2013 | Dryers
I have a neptune mdg5500aww dryer, goes on, glowing igniter... but does not turn on the gas... what is wrong
Their are 2 possible things wrong;
1) Does the igniter just stay on or does it glow and go off usually within 1 minute?..if the igniter just stays on and never goes off the FLAME SENSOR will be the problem
2) if the igniter does glow then go off but no flame..the coils that open the gas valve are bad
The part numbers are;
FALME SENSOR 338906
GAS VALVE COILS 279834
The parts could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Aug 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
The dryer heats up at first but the burner won't ignite after it cycles off. The ignitor comes on but no flame. I changed the rear thermostat on the vent housing but that did not resolve the problem.
you have bad gas coils.when they are starting to die the dryer will run normally for the first 10 to 30 minutes and then no flame,the coils work fine until they heat up then nothing.when they cool down you'll have a flame again.easy fix,the coils are on top of the gas valve,take out the two phillips screws,remove the metal cover and change out the coils,that's it part number 279834.let me know how you make out
Jul 17, 2010 | Kenmore 74602 Gas Dryer
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag SDG3606A Gas Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
