Question about Zodiac Baracuda G2 - In Ground Suction Side Automatic Pool Cleaner
Baracuda pool cleaner won't work
We have bought a new skirt, foot & diaphragm but the Baracuda cleaner won't vaccuum
  • 106 Answers
SOURCE: get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Posted on Jan 15, 2010
  • 106 Answers
SOURCE: My Baracuda pool cleaner doesn't work at all
While the cleaner is in the water, see if there is suction on the bottom of it. If not than you probably have a bad hose.(Broken) If there is a lot of suction then the diaphragm probably is either worn out or has a rip or tear in it.
Posted on Feb 24, 2010
  • 366 Answers
SOURCE: My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Posted on Apr 08, 2010
  • 106 Answers
SOURCE: I have a baracuda pacer pool cleaner and it seems
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Posted on Apr 19, 2010
Testimonial: "thank you for your suggestion I will try this solution of changing the hoses around"
  • 990 Answers
SOURCE: Can Baracuda Diaphragm be replaced?
If you can't find any junk in the diaphram or throught. The best thing to do is take it to a store they can show you how to do this and they will not usually charge for more than just the part.
Posted on May 28, 2010
Testimonial: "Thanks - I will take it in and have them look at it."
Diaphragm housing unscreews from the baracuda
is the motor mounted on a dampening plate? do these screws have lock eashers behind them? may need to install these..
Oct 18, 2013 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac ranger has good suction but doesn't move
Usually if you have good suction with a Baracuda and no movement you either need to clear the diaphragm of debris, or replace the diaphragm if it's got a hole in it.
Check out this video (not mine) for how to pull the diaphragm out.
http://www.youtube.com/watch?v=FRR1Gsps8Js
It's pretty straightforward, just keep undoing things until you get to the flexible rubber bit. You have to check fairly carefully for holes because even the smallest opening means it's curtains for the diaphragm.
Good news is though that Zodiac should have a 1 year warranty on the diaphragm, which you can check by looking at the moulded stamp on the part. If it's under a year old your local dealer should just swap a new one for the old without any dramas.
Mar 16, 2013 | Zodiac Baracuda Ranger - Above Ground...
Wont move,has suction but wont move?
If cleaner is pulsing, you probably have a worn out foot pad and it should be replaced. If it not pulsing, you probably have a ripped or torn diaphragm and it needs to be replaced. Also, make sure there is enough suction.
Aug 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
How to install new diaphram
Page 8 in the users manual for these pool cleaners has a good image of the diaphragm. There is also an assembly break down on page 10. Here is a copy. It should show you exactly how to get the cleaner apart to replace the part.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jun 12, 2010 | Zodiac Baracuda G3 Automatic In Ground...
May 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Feb 24, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac Baracuda G2 - In Ground Suction Side Automatic Pool Cleaner Logo
16 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
