Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Frig Freezes Up
Our botton freeezer stays cold but does not freeze ice cream and the like. Sometimes the top refrigerator does not keep things temperature milk, etc. We have cleaned the coils. About once a week we have to dethaw the coils on the back because they are covered in ice. There is no ice build up on the inside of the freezer but this past week, we have started having water pooling out from under the front of the freezer. The compressor has already been replaced once on this and it was expensive. I would like to try to fix this myself, but don't know where to start. This fridge is only 5 years old and I think they for how much they cost they should last longer than this.
  • 2,692 Answers
Usually it is one of two problems. Either the defrost timer is acting up ( staying on too long or not  going off soon enough. It is usually . More likely is a refrigerant leak. Her is a easy way to tell. the compressor whould be warm when running, not hot The coils that you cleaned shoud be warm at one end and change tempature as it goes to the other,but never cold at the top. If the compressor is hot or the condensor(coils) are cool the you likly have lost part of the charge. If that be the case you have a leak and if you have it serviced it is the law that they find and fix the leak m, not just charge it up.  It is now necesaary to have a EPA license to buy the refrigerant.  Sorry.
Posted on Jan 03, 2009
Can you tell me how this ice cream machine works
The basic old style ice cream maker worked by putting the ice cream ingredients inside the center container and the motor device on top turns the spatulas inside to mix it up. Then you put ice and water and salt in the outer bucket. The ice and salt make it very cold so the ice cream freezes as it churns. Some newer devices, just have a mixer and you put the whole thing in your freezer to make it freeze.
Dec 11, 2014 | Ice Cream Makers
We bought our frig exactly 6 years ago (to the date!) and suddenly the frig part is cool, but not cold, while the freezer section stay cold and ice is frozen.
Check your freezer section ! Is the coil frozen over ? If so it may have a burnt out defrost element or a bad defrost timer. When the freezer coil freezes over cold air is restricted to the refrigerator section.
Jun 03, 2011 | Refrigerators
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Ice forms in on the back panel in the freezer; freezer stays cold but frig not as cold; we defrosted it, took everything out of the freezer and relocated so as to keep items away from fan. Plugged it back...
Make sure that when you have removed the ice you also cleaned out the unit especially the freezer and the drains. Clogging due to dirt is sometimes the cause of coils to freeze up. I would advise to have the thermistor checked. I am unsure if your unit has auto defrosting capabilities, if it has you may want to have the circuit checked out.
Sep 06, 2009 | Whirlpool Refrigeration 14.4 Cu. Ft....
Ice Maker inlet tube freezes up.
Try runnning a manual test of the defrost cycle, could be that you are not getting enough airflow to the frig side, while the frig side is calling for more cold. Becuase the frig side is calling for more cold, and not able to get there it is causing more airflow across the water tube.???
Aug 16, 2009 | Frigidaire Refrigerators
Has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
OK send me the model number as found in photo below. You may have a circulation problem that I will be able to look over closer when I have model number. Sea Breeze
May 25, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
