Question about Hotpoint NBXR463EBWW Electric Dryer
Condenser Dryer Still Filling Room With Moisture
Hi, I have a Hotpoint condenser dryer, which has always leaked hot moisture into the room. I had never owned one of these before, so as it always seemed to fill the container with masses of water, I just assumed that the moisture in the room was normal. However, everyone I speak to who has a condenser tells me it never causes any moisture in the room at all. Since day one mine has caused all windows to instantly mist up and all surfaces in the room to be visibly wet. But it does still produce reasonable amounts of water in the container as one would expect it to. Unfortunately I have only realised this flaw now that my warranty has expired. Can anyone advise on what might be wrong? Thanks, Craig.
  • 5 Answers
I have a condenser dryer and when i remove the container which collects the water, it is swimming in water as if something is leaking or blocked.Does anybody know what the problem is
thanks
Helge
Posted on Dec 28, 2007
If all else is ok try ventilation, I know it sounds obvious, however all homes are different and perhaps leaving a window ajar might help. (of course do not leave the house if the window is opened). one other thing try experimenting with different loads as some washers have a higher capacity than the dryer, so for example a 7kg load in a washer would not transfer to the capacity of a 6kg dryer if you could get all the cothes in. Even if the 2 items have the same capacity the wet clothes take up more space, and the dryer is more efficient with some room. Also try a higher or extra spin depending on the type of clothes being washed. Tony
Posted on Oct 02, 2007
Hi, It's a Condenser dryer, so it does not have an exhaust. It condenses the moisture back into water internally and stores it in a removable container, which I need to empty after every use. Cheers.
Posted on Aug 12, 2007
    Novelist:
  • 159 Answers
All dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
Posted on Aug 10, 2007
LG WM3431H during dry cycle condensation builds on inside of machine and then underneath, cleaned all lint out already
usually do to condensation which is a result of bad venting in the blower, the tubes, the glides, and the door, and even a bad moister sensor check it with a meter for continuity and for amount of ohms but at a high temperature not room temperature
Feb 21, 2013 | LG WM3431H Washer and Dryer
Water coming out front of condenser
It is difficult for me to understand why any water should be coming from the dryer. Your washer maybe the fault, clothes should be, at best, damp from the washer with very little excess moisture. Check to see if your clothes washer is spinning, if necessary try turning off the water supply to the washer and run another rinse/spin cycle, if your clothes are still wet or dripping then your washer needs repair. Check that first... And report back
Jan 21, 2013 | Hotpoint TDC32 Electric Dryer
I'm currently servicing a sub zero side by side m#3211RFD with Hot Shot in the system. My guage pressure on high side was almost 300psig and suction pressure 10psig (refrigerator section) room temp 85F...
No I think you will get further by removing all the refrigerant, and pulling a good vacuum on the system... there seems to be dirt or moisture in the system...make sure to run the refrigerant through a filter/dryer before reinstalling into the system again...
heatman101
Aug 13, 2011 | Refrigerators
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
New Condenser Dryer creating sauna in utilty room
Howdy: All dryers need a escape vent do to heat. Please read your manual and see what needs to be done. Good luck - Doug
Dec 09, 2009 | Dryers
My new hot point gas dryer takes several hours to dry a med load of clothes. It has now started to gather moisture on the inside of the door, when I open it. I keep the filter clean, sometimes twice when...
Your dryer is not venting like it needs to, or the room that the dryer is located is too air tight.
Clean out the outside louver for the dryer. If you can, remove it so that you can see down the pipe. Remove as much lint buildup as you can. Go back inside, and remove the dryer vent hose from the wall, and again, remove as much lint as you can. Then do the same with the vent hose at the dryer connection. Reconnect everything, and it should start working better.
I mentioned the room being too airtight because it can happen, but is a rarity if dryer has not been relocated and problem occurs. Dryers take in room air, heat it, send it through the drum, and then out the dryer vent. If the room is air tight, then it won't be able to move much air, and cant' expel the moist air like it needs to.
Aug 29, 2009 | Hotpoint Dryers
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
Hotpoint condenser dryer drum workinbg no heat
check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Apr 23, 2009 | Hotpoint Dryers
Dryer not taking out moisture
your venting from the dryer probably also submerged in the "flood", try taking that apart and make sure its not clogged, sounds as if the dryer is not able to release the heat that its producing
Jul 25, 2008 | Dryers
Splendid washer and condensing dryer combo
Since the clothes ARE getting hot, it's not the tripped breaker(s) mentioned in Solution #2, because these would cut off power to the heating element(s).
Since it's a Condensing dryer, it can't be an obstructed exhaust hose, either (as there is no dryer exhaust).
Remove the lint filter(s). Holding it over a sink, see if water flows through it. The waxes in "dryer sheets" clog lint filters and, even though invisible to the eye, can totally obstruct the air flow and stop a dryer from drying. Wash it with soap and water.
Question: Does your dryer have a small drain hose leading out the back and going down a drain? If it's clogged, the dryer can't remove any more moisture. If there's no drain, then you have an internal "catch tank" to collect the water evaporated out of the clothes. It's supposed to be emptied after every load. Empty it.
If that's not the problem, I suspect your condenser is not working (removing moisture from the hot stream of air blowing through the wet clothes. This could be because: (1) It's clogged - Take out the boxy thing (technically called a heat exchanger) made of thin aluminum "fins" or tubes, and wash it off in the sink. or (2) The little fan that cools the condenser isn't running. In this case you'll need to call a technician. Good luck
Dec 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
235 people viewed this question
Top Hotpoint Dryers Experts
shaun taylor
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
