Question about Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp
Mower run good until its ward up than its start hit and miss then dies. then its start right up . run a little then dies
  • robert nelson Oct 27, 2012
    new spark plug clean in cycliner
  • robert nelson Oct 31, 2012
    put new plug in it and clean carbon .still doing same thing
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
Carbon build up in engine or fouled sparkplug
Posted on Oct 27, 2012
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
I have a Poulan push mower that after mowing in a ditch started making a loud noise and running rough. It almost sounded as if metal was hitting metal. The mower was vibrating more than normal. I checked...
If you are sure the oil level is correct then it sounds like it's about to die, unfortunately. A pine cone shouldn't cause any damage, but a large branch may do so. Was it smoking before you shut it down? The vibration could be caused from a bent blade. It could also be caused from a part breaking in the motor. I wish I could have given you better news!
Good Luck,
Jim
Aug 13, 2011 | Poulan "Poulan" Push Mower
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My husband replaced the diaphram on our Poulan Pro 5.5. After reassembly it will start and then die. He thinks he missed something when putting back together. Any suggestions?
To me it sounds like it is starting and running off the fuel from the priming. You could try after it starts to hit the prime bulb just before dying to see if you can keep it running. If that works then I would say that something is blocking the little holes in the carb. Could be trash in the tank. Anyway I would get some carb. cleaner (can get it at the store he got the diaphram from or from walmart back in the automotive chemical section). Then take the carb. off and clean it out blowing the carb. cleaner through all passages making sure that the cleaner comes out somewhere else. It is a good idea to have a face shield or safety glasses for this because the cleaner can come back up at your face and you do not want this stuff in your eyes. Be careful and good luck.
Jul 07, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
Car dies when it heats up and won't crank back up until cooled
normally a speed control sensor can solve this problem, but also check the crank senson.
Aug 24, 2009 | 1993 Buick Skylark
Runs rought
try a basic tune up on it,,, should help,, air fiter plugs,,, good luck
Aug 12, 2009 | Garden
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
Murray lawnmower
you may just need to remove the nut that holds the float bowl, and inspect the nut itself, half way up the nut should be a little tiny hole in the side.
use a bread tie stripped of the plastic covering and unclog this little hole, then replace the nut , when that hole becomes plugged the main jet cannot get fuel for the venturi pipe, thus the mower will start and hit a couple times then die immediately, that may fix the problem
Sep 15, 2008 | Garden
Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp Logo
125 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
