Question about Verbatim Inkjet Printable DVD+R Discs - White, 50/Pack(sold ins of 2) (81976646SEMQ2) Media
How to print on printable dvd
How do you print on them
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
Use a magic marker
Posted on Oct 27, 2012
How on earth do I print on a CD disk. Not explained in the online manual! Can't find no software??
there are printer that print directly on cd-dvd (printable ones).
for the ones that dont print them directly there are printable cd-dvd stickers,they are on a4 paper, you print them like any paper and you remove the pre-cutted stiker and put it on your cd.
Aug 25, 2013 | Office Equipment & Supplies
Verbatim CD-R 52X Printable disc. What does the term ' Silver Inkjet Printable" mean and how do I use it. Thank you.
> silver inkjet printable
It means that in addition to the "bottom" of the disk being capable of being "burned" by a CD/DVD writer, that the "top" of the disk is capable of absorbing ink, if you put the disk (instead of a sheet of paper) through an inkjet printer, and print some images/text onto the surface, to create a professional-looking label on your disk.
Oct 19, 2010 | Computers & Internet
Ink won't dry on lightscribe
You need special absorbent coating on the printable DVD's if they are suitable for that. Are you sure you can print on the sort you have usually they are all white. It also must actually say suitable for PC printed labels etc too.
Jun 18, 2010 | Verbatim (95058) 25 Pack 16x DVD-R Storage...
WHAT SIDE OF DVD DISC DO I PRINT ON. HAVE PRINTED ON YELLOW SIDE BUT EVEN AFTER 12 HRS IT SMUDGES.
You need DVD's that are labeled Ink jet printable. The printable side is most likely a plain white surface. On DVD-RW's you will probably need a Sharpie Pen.
Oct 25, 2009 | Sony 2DPW47 DVD+RW Disc (2DPW47) Storage...
Ink leaking on to dvd when printing label
Are you using a printable CD and telling the printer that that is what it has to print on?
Jan 30, 2009 | Epson Stylus Photo R200 InkJet Printer
Canon pixma 4500
HI
FIRST YOU HAVE TO MAKE SURE YOU HAVE PURCHASED THE CORRECT WHIT PRINTABLE DISKS.
YOUR PRINTER WOULD HAVE CAME WITH THE NECESSARY SFTWARE CALLED CD PRINT.
OPEN THE PROGRAM AND FOLLOW THE INSTRUCTIONS TO CREATE THE IMMAGE ON THE CD/DVD.
YOU WILL BE WORKING WITH AN IMAGE OF A BLANK WHITE DISK, AND WHAT EVER YOU DO THERE WILL BE PRINTED ON YOUR REAL DISK.
YOUR CANNON PRINTER WILL HAVE AN OPENING IN FRONT WHERE YOU WILL HAVE TO INSERT THE DISK WITH THE PROVIDED TRAY ( A BLACK RECTANGLE WHICH THE CD/DVD WILL FIT ON).
FOLLOW THE INSTRUCTIONS ON THE PC AND YOU CANNOT GO WRONG
Jan 08, 2009 | Canon Pixma iP4500 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Image print on disc
Lightsribe disc is only monotone colour mostly its gold color.
So if you want to print an image on it.
Probably you will not like it.
Instead buy an Epson R230 or newer series. Because it has CD printer.
It can print beautiful colors you want.
Buy also printable CD. It can be generic CD or branded like Verbatim, Sony, TDK, Melody.
Buy a printable CD with a paper texture on the top.
If not it might smudge the ink on the top.
Its messy.
Well then. I hope this help
Jun 15, 2008 | Computers & Internet
Is there any way I can burn an image onto a printable cd/dvd using a burner either through my printer or directly from the burner?
1) buy a printer with cd/dvd print tray - like canon 4500, it prints on printable dvd only (printable dvd's have a special white coat to absorb the ink).
2) buy a dvd burner that supports lightscribe like asus drw-1814bl (it prints black only on special coated "lightscribe dvd's"
3) NOT RECOMENDED but also possible, buy cd/dvd labels print on any printer and adhere to cd/dvd, usually over time the glue will destroy cd's and trapped air will make bubbles when the cd/dvd is hot (air expands in hot environment).
Shapirit Computers
050-2330137
www.shapirit.biz
May 04, 2008 | Office Equipment & Supplies
Verbatim Inkjet Printable DVD+R Discs - White, 50/Pack(sold ins of 2) (81976646SEMQ2) Media Logo
50 people viewed this question
Top Verbatim Electronics - Others Experts
Are you a Verbatim Electronics - Other Expert? Answer questions, earn points and help others
