Question about Crown 2 Din Universal 7 Inch Touch Screen Dvd/cd/sd/usb Car Player Rds Radio Warranty
Touch screen car stereo says
The touchscreen screen says "cam" in the upper left corner and "no signal" in the middle of the screen when i plug it in. it doesnt do anything else, the buttons dont do anything and neither does the remote.it says to connect the pink wire with the ground wire in order to get the picture on the screen and i did that and to connect the orange wire with the 12v wire so it will be switched to the video backlight input. and i did that.
I plugged in my Garmin Nuvi 40LM to the computer and got the updates. But my keyboard is still not responding correctly. I push 5 and get a 6 or push T and get a Y. Any ideas?
Try recalibrating the display. Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and hold it there while pushing down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press all of the dots as they are presented. Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display. If this doesn't resolves your problem. then your touchscreen may be defective.
Feb 25, 2016 | Garmin Nuvi 40Lm - Gps Receiver
Tip
How do I let my Wireless Be found by my iPod
<p>The iPod Touch comes with Wi-Fi compatibility, so it can connect to any wireless network at home or the public. At the time of publication, the iPod Touch is the only Wi-Fi compatible. Connecting to a network requires a few steps. If your wireless network requires a password, have it on hand before you begin. <br /> <p><br /> <p>1. Touch the "Settings" on your iPod Touch. By default it is located in the upper left corner of the screen, although you may have moved. He is gray with a gear icon. <br /> <p><br /> <p>2. Go to "Wi-Fi and make sure it says" On. "Slide the switch to" Off "to" On "if needed. <br /> <p><br /> <p>3. Wait until your iPod to signal detection network. It may take several seconds. <br /> <p><br /> <p>4. Select the network you want to join the list of available networks. Your iPod can detect more than one signal in your area. <br /> <p><br /> <p>5. Enter the password to the network when prompted, if necessary. The iPod Touch will ask you automatically if a password is required. <br /> <p><br /> <p>6. Tap "Join" and press the Home button to return to the main screen. The Wi-Fi icon in the upper left corner of the screen lights up and shows the signal strength. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How to Upload Music to your iPod Touch
Instructions:<br /> <br /> 1. Open iTunes on your computer. <br /> 2. Plug the iPod USB connector into a USB port. Plug the other end of the connector into the bottom of the iPod Touch.<br /> 3. Look for the iPod Touch to show up in the Devices column in the middle left corner of the iTunes program screen. Once it does, you have two options. You can have all the songs/music from your personal music library/file sync with the iPod Touch every time you plugged into the computer, or you can create a playlists and manually selecting them for syncing.<br /> 4. Click on the iPod Touch symbol in the Devices column once you've decided which method of music management is best and suits your preference. A screen will pop up, giving you the summary of information about your iPod. Click on the options you want, then proceed to the bookmarked section labeled "Music" in the upper middle section of the page.<br /> 5. Click the "Sync" button in the bottom right corner of the screen. When the music has finished its sync process, a message at the top will appear "iPod Touch sync is complete. OK to disconnect.<br /> <br /><img src="fossildude.jpg" />
on Jan 06, 2011 | Audio Players & Recorders
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
Garmin 2720 touch the (s) and the (T) responds
You need to recalibrate the touchscreen. Try this: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Go through the entire procedure of pressing each dot as it appears on the screen.
Once completed the Nuvi will display Calibration Complete This will recalibrate your touchscreen to the LCD display.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Feb 11, 2014 | Garmin nuvi 205 GPS Receiver
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
Dec 04, 2013 | Elo Computers & Internet
Garmin Nuvi 1300 touch screen not working
It sounds like you need your touchscreen replaced. The touchscreen is soldered to the LCD display, so the touchscreen must be unsoldered from the LCD display and a new touchscreen resoldered to the LCD display. Please do not attempt to do this yourself. You can easily damage the LCD display in the process. More information about touchscreen replacement can be found here:
Apr 21, 2013 | Garmin nuvi GPS
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Mar 29, 2013 | Garmin nuvi GPS
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Press each dot to recalibrate the screen.
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
Crown 2 Din Universal 7 Inch Touch Screen Dvd/cd/sd/usb Car Player Rds Radio Warranty Logo
21 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
