Question about John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
Cub cadet lt1040 pto won't engage - John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: PTO won't re-engage after mowing
Check the PTO switch for proper closure. This implies that the contact plate may need to be adjusted to ensure that the switch closes. Check the PTO clutch itself by separating the connector at the flywheel. Jumper the black wire to ground. Jumper +12v from battery to the blue wire and listen for a click. I've had some issues with mine as far as the micro switches lining up with their contact plates. As I recall there's also one near the PTO brake band that gave me some trouble. Of course you need to fully release the parking brake, which could have fallen into a light contact mode when you stopped hard like that. Seat, brake, PTO engagement lever and parking brake are all the pssible hangups. Looks like the connector blocks and junctions cause problems, too.
Posted on Aug 22, 2011
Im looking for a wiring diagram for cub cadet lt1040 riding mower
https://www.partstree.com/parts/cub-cadet/mowers-lawn-garden-tractor/104-cub-cadet-garden-tractor/wire-diagram/
wiring diagram for cub cadet lt1040 Google Search
May 22, 2016 | Cub Cadet Garden
Blades won't stay ingaged
bad pto clucth overheating shutting off
Apr 07, 2013 | Cub Cadet Lawn Mower Electric PTO Clutch...
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Sep 25, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Logo
117 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
