Question about Zanussi F1245W Front Load Washer
Drive belt out of alignment
Machine has been making a bit of noise lately when spinning. I took the back of today to have a look and the drive belt going around the wheel with the spokes seems to be slipping towards the drum side of the wheel and cutting into the plastic. The motor wheel - the one with grooves has the belt set to the extreme outside to try and prevent this. There does not seem to be much slack in the belt itself but appears to be more of a misalignment. Any ideas ?
  • Chris Neville May 14, 2007
    what do you mean by pulley being bolted fully home ? None of the spokes are cracked/broken. Should the belt be really tight, It seems to stay on during the spin, but as the spin gets faster, on the very final top speed, the belt rubs against the plastic casing of the drum back and becomes noisy. Do you think a new belt would be tighter and would maybe stay on.
  • Chris Neville May 19, 2007
    thanks, got the new belt, helps a bit if I have it overhanging the groove on the motor spindle but this causes the drum to rotate erratically. Any ideas how I tighten the bolt. I used a socket and the pulley wheel kept turning so I wedged something between it and tried to tighten it but it feels tight already. Do I have to take the whole drum out and apart ?
    President:
  • 1,462 Answers
Check pulley is fully bolted home. also fault could be due to the bearing spider (on the drum) being broken or cracked on one leg. if this was so, would expect spin with clothes to be very noisy. get gack to me if you want. the belt is a stretchy belt ie no adjustment for tightness
Posted on May 14, 2007
  • douglas smith May 19, 2007
    new belt may help and it should be really tight. however, i think the root cause is drum pulley out of line with motor pulley for the reasons described. pulley is held on to drum shaft with a bolt and make sure this is tight. it is an odd fault
Maytag Neptue frontloading washing machine model MAH5500BWW stopped spinning (machine is about 15 years old). I opened up the back and saw the drive belt was thrown. Reinstalled it (perhaps badly) and...
i would say you have a warped main pulley, run the machine in spin,watch it early to detect any wobling in the belt should be no sideway movement. also check main pulley is tight with no lateral wobling.
Dec 21, 2010 | Washing Machines
Washing machine went bang and wont work. The plug fuse is fine and the washing machine light comes on but it wont work
It should be the machine that has died. If you're unsure you can do it, call your appliance store's technician. Do not open it esp. if it's covered by a service warranty. It will become void if you do. I had the same experience before and the technician really took out the machine and brought it back to their branch office.
May 27, 2009 | Washing Machines
Whirlpool washer... terribly noisy...
Hi, THe shaving are from th ecoupler. THis connects the transmission to the motor. Does the noise accur in both spin and agitate? The coupler wil need changed.
Please let me know if I can assist you further. Part #285753 $15.95
I have this part on my web site www.whirlpoolpartssurplus.com
Thanks
Vic
May 18, 2009 | Washing Machines
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Sep 20, 2008 | Washing Machines
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Washing machine problem
Sure you need to lubricate. But change the belt, you get all sizes easily. The wiirring noise is usually when the belt is off, worn out likely.
Pl rate, thanks
Dec 27, 2007 | Hoover PE235 Front Load Washer
Drive belt and noises.
your drum shaft is broken this is making the pulley wobble causing the belt to come off and it will also explain the noise. This is a very expensive job sometimes requiring the complete tub to be changed might be time for a new machine
Jul 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Zanussi F1245W Front Load Washer Logo
279 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
