Question about Skil 4680 Jig Saws
Blade keeps rotating when running in my Skil #4680; what needs to be replaced?
Spindle just rotates freely and will not lock in straight so I cannot cut a straight line,
5 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Posted on Oct 13, 2009
  • 172 Answers
SOURCE: I broke the lower blade guide
All I could find out is that your skil bandsaw is made by the Bosch Bench tool co in Mount Prospect, Il. The owners manual from skil shows the part you need as #6 lower blade guide, and Lowes does handle this line of Skil. I would suggest contacying Lowes or the store you bought this from and getting the consumer help phone number from them. They have to have this part available as I am seeing a lot of these units refurbished, so someone has the parts to them. Hope this helps and good luck. Marvin
Posted on Jan 20, 2010
agent91
  • 2100 Answers
SOURCE: I just bought a Skil Band Saw and it wants to cut
You probably just need to track the blade, pull all the guides back away from the blade and free wheel it by hand, tilt the blade into the center of the tires, if it doesn't center on both, one of them is off. When it centers, torque it up a little, then adjust the guides to the blade, don't push the blade out, just barely touch it, then it should track and cut straight. Good luck. Does this machine have a transmission for metal cutting? Or just one speed?
Posted on Feb 11, 2010
awcforever
  • 359 Answers
SOURCE: how to replace saw blade on skil saw
On the side of the saw in the center of the blade, there should be a bolt to remove that will get the blade off. Some saws have a special wrench needed to remove it, but since you have a Skil, you should be able to use either a 1/2" or 9/16" wrench or socket to take it loose and switch the blade out for one of your choice. Hope that helps.
Posted on Oct 09, 2010
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
Where is the blade lock on the skilsaw 5155
Hi Emory:
Your question made me think................
None of the skil saws that I have owned, or still have, came with a blade lock. Maybe yours has one, but if I needed to pin the blade while undoing the bolt, I'd do like I always did......... Unplug the saw....... and slip a carpenters pencil between the teeth and rotate the blade until the pencil came up against the deck.
There is also usually a hole in the blade, and a nail slipped through the hole makes a perfect blade lock.
Oct 03, 2015 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Something's preventing the blade from rotating
burn up, or the blade is so warn its in lockmode, perhaps if that's not it, and you recently changed the blade make sure that is was put on correctly, and the guard is not hung up
Jan 28, 2014 | Skil 5250 Circular Saws
How do I lock the blade spindle so that I can loosen the blade stud to install a blade?
there is usually a button on the front of the saw that you push in while you try loosening
Dec 28, 2012 | Skil Saws
How do you change the blade on a miter saw
first unplug the tool, raise the head and loosen the bolt that holds the lower guard in place. DO NOT disassemble the lower guard, pull it down and it will move out of the way somewhat. Next there is a spindle lock that you push in rotate the blade until locked and hold it while removing the hex bolt, which should be left hand thread, I would use a pair of gloves when holding the blade just for safety. Remove the outer flange and spacer (if needed) reassemble in the opposite order and before trying rotate the new blade by hand to make sure turns freely. Let me know if you need more assistance.
Feb 16, 2011 | Saws
How do I disengage the drive shafts to tighten a
should be a black button between the handle and the guard. Spin the blade until it depresses all the way down and you should be able to loosen the blade.
Dec 05, 2009 | Ryobi P501 18v Circular Saw Only
Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Mar 10, 2009 | PfaFF Tiptronic 2040
Skil 4680 Jig Saws Logo
118 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
