E2 code on a tuscany twmtl6 wasing machine what does this indicate
Does not spin water out jus comes up with an E2 code on the screen
SparkGap
  • 363 Answers
SOURCE: Haier HWM5TL E2
I looked at the Haier website and all other usual sources but could find nothing. I think you should e-mail service@haier.com.au with the same query. Good luck
Posted on Sep 30, 2007
  • 416 Answers
SOURCE: Error E2
It is drain pum error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Good Luck
Posted on Jan 08, 2009
SOURCE: the machine cycles to 35 min. then beeps and shows E2.
clean the debris filter.
Posted on Jan 21, 2009
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
SOURCE: Heller awm600 washing machine e2 error on spin
BROKEN PIECE OF PLASTIC ON LID CAUSING MACHINE TO THINK LID IS OPEN ALL THE TIME. REMOVE LID, WEDGE BROKEN UP SATAY STICK INTO GAP, REPACE LID AND VOILA!! WASHING MACHINE SPINS AND ALL FOR LESS THAN 15 MINUTES WORK AND A STICK!
Posted on Jan 10, 2010
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
What does the fault code e2 mean?
Kenmore e2 code Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > e2 code > Washing Machines
Kenmore washing machines e2 code related questions and answers. Ask yourKenmore questions. Get free help from washing machine experts.
Jul 26, 2015 | Washing Machines
Just installed, shows error code E2, is not heating water
May 22, 2015 | Water Water Heaters
The problem with xqb90-701 machine comes up with e2 code will noy rinse ,empty or spin
I don't know what the codes are for this washer but it sounds like it has to do with the pump not coming on and pumping out the water. most of these front loaders have a clean out for the pump filter you should find it between the pump and where the drain hooks up to the tub. many times they get clogged with stuff. I worked on a whirlpool the other day that had a large sock stuck in it.
May 09, 2014 | Washing Machines
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Telmann washing machine TEL6TL
Telemann TEL6tl E2 Problem
E2 on screen means the lid is not closing properly and thus not activating the (hidden) switch that prevents the machine from spinning while the lid is up.
The lid switch in this model is not a direct contact switch between lid and switch , but it switches on and off due to a MAGNET embedded in the lid on the left hand side near the front. You will see a small indentation where the magnet SHOULD BE. My magnet had fallen off, so the lid could not activate the operation switch. I had lost the original magnet( about 1cm X 2cm) so glued another into place.
Machine is now fully operational again, and the job cost .78c.
If your magnet is still in place, the E2 fault could lay with the switch itself , which is fixed to the underside of the top casing of the machine near the front right hand side of the lid cavity. The switch measures 1cm X 3cm heavily black tape insulated. Access is gained by popping the 2 X2cm discs at front top of machine and releasing the 2 small philips screws here and a further 2 at the back top of machine. This operation of replacing the switch is best left to an electrician or washing machine specialist.
Hope that helps
Apostle95
Nov 01, 2008 | Dishwashers
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Jul 26, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
