Question about Amana BX21V
I have an Amana BX21VW refrigerator with freezer on bottom. The freezer is no longer keeping food frozen. What is the most common reason for this?
I took the back cover off (inside the freezer) and it is frosted up on a small portion of the coils in the upper right corner of the freezer. I had a freezer do this before, and the technician changed a heater bulb that keeps the back from freezing. I don't see one in this freezer.
    Top Expert:
  • Amana Master
  • 9,472 Answers
You will need to replace the "defrost thermostat" located on the freezer coils. Here is the part you need.
Posted on Oct 27, 2012
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
  • 87 Answers
SOURCE: SZD27MW - Freezer Fan not working - temp runs 40 midway in freezer
Voltage is either 240V or 110V either way it is stamped on the fan motor. You have a sensor controlling the fan and heater which could have gone open circuit and on some cabinets they use the neutral through the heater to bring in the fan so you could have a heater gone. You can bypass the sensor but this should not be a long term solution as it is a safety mechanism. Hope this helps.
Posted on Aug 17, 2007
SOURCE: Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Posted on Jul 10, 2008
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
  • 15 Answers
SOURCE: freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
Posted on Jun 01, 2009
I have a Frigidaire FRS26R4CWE both the Freezer (30 degrees) and Refigerator (41 degrees)were not cold enough. This a spare basement refrigerator that we use once in while. There was no ice in the bin....
Hello;
My name is Peter. I am a retired field service refrigeration technician.
When you removed the freezer you should have seen a even frost pattern across the cooling coils.
If you have ice at the top especially in the upper right have corner, then you either have a restriction or a refrigerant leak. In the upper right hand corner you have a very small tube with a inside diameter the size of a small needle. It is not uncommon on older units for this tube to become plugged up or leak.
A repair of this nature by a service technician would be about $550.00 USD.
Feb 16, 2015 | Frigidaire Refrigerators
I have a godrej refrigerator, pentaciol model. in
My name is Peter, retired Sears Home Services Tech. You must know something to mention the Bi-metal. When you pull off the back wall freezer cover do you have a nice frost patter on your evaporator coil? Is there allot of ice in the upper right hand corner? If so you have a restriction. This means the evaporator coil & the line filter has to be replaced. This is a major repair by an experienced tech.
This is about a $450-$600.00 repair.
Oct 11, 2014 | Refrigerators
An old kelvanator freezes in the refrigerator compartment
Normally in most situations if you are getting ice forming on the coils, and I mean ice, not frost, on either coil, be it freezer or fridge chances are you have a refrigerant problem. A good indication of this would be to expose the coils and see if the ice is localized, or more so concentrated in one portion of the coils, i.e. upper right corner, etc. Going further into the problem, the two things that would cause this is (1) a restriction in the line, (2) low pressure in the lines which is because of a leak or weak compressor. To really diagnose this problem accurately you need a set of refrigerant gauges and tap into the low side line of the sealed system.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 20, 2012 | Refrigerators
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana AFI2538AEW. Most of my Vegatables in the crispers are freezing and a bottle of milk in the back is frozen also on the shelf. Can you help me?
heatman101
Apr 30, 2011 | Amana AFI2538AE (25.6 cu. ft.) Bottom...
Keeps getting error code dh and the fridge isn't staying cold now
Your refrigerator is telling you that it is not sensing a current flow through the defrost heater circuit within a certain number of hours. Could be a bad defrost heater, or a thermostat / fuse package located in the upper right hand corner of the freezer, behind the back wall of the freezer compartment. The reason the refrig is getting warm is that the cooling coils (behind that back wall of the freezer) are blocked up with frost, preventing air flow across them and on up into the refrigerator compartment. It is a bit of a pain to get the back wall out inside the freezer, but it will have to be done. Melting the frost off the coils with a hair blower will temporarily solve your cooling problem, allowing a week or so to get the part(s) you need.
Feb 07, 2011 | LG LFX25960ST Stainless Steel French Door...
Bottom Freezer of the Amana serial number: ARB2214CW gets over frozen and starts to create snow over frozen food. What number cold should be on to just keep the food solidly frozen without the above...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 20, 2010 | Amana ABB1927DE Bottom Freezer...
I have a GE side by side model #tfx22jrba ww and it is leaking. It is wet under the left front corner. I took off the grill to see if I could find the drip pan and see if it was full but didn't see it. Any...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Sep 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
116 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
