Question about Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive
FINDING SERIAL NUMBER FOR BUFFALO HD-CE500U2 & PC NOT RECOGNISING
I am having trouble with by HD-CE500U2 not being recognised, light is on and it is lightly virbrating but the device manager is telling me that there is an error code 43 and there are no drivers. When I go to the web site to download drivers, it asks for the serial number. I have thrown out the box and the serial number on the bottom has been rubbed off. Please help!
Crankstart
  • 696 Answers
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 09, 2009
Crankstart
  • 696 Answers
SOURCE: My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
bob_computer
  • 3153 Answers
SOURCE: I cant format my Buffalo HD-CE500U2. It took time
A few things to check
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there then lets see if we can format it ?
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Posted on Aug 23, 2009
LCPLgeek
  • 125 Answers
SOURCE: formatting a buffalo hd-ce500u2
hi there, if you would like to format it, all you have to do is plug it into the computer, go to my computer, and right click on the drive. Then, click format. After that, click on the format button and let it be for about a hour or two. After it is done, the drive will have been formated.
Posted on Jan 30, 2010
  • 130 Answers
SOURCE: my buffalo external hard disk
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Posted on Apr 13, 2011
How do i recover serial number on buffalo ministation HD-PNTU3
Load Nas Navigator2 and it will bring up it's built-in web page. When it finds it it will display it's properties inc. serial number. The default user is 'admin' and the password is 'password' as default.. unless you have changed that. If that doesn't work look to Buffalo Support as they are very good.
Oct 12, 2014 | Buffalo Technology MiniStation Computers &...
Buffalo external hard drive not recognised on car sterio
i think you cars stereo firmware is not capable check whether other external hard drive it is recognising
Feb 05, 2013 | Buffalo Technology 1TB DriveStation...
I cleared up my HD-CE500U2 earlier and deleted everything I didn't need and since then, I have restarted my computer and the light on the drive is on, but it isn't being recognised by my compu
there is only one way put another harddisk on your system and install the os which you have in old one after installing it and remember do not open any disk untill you didnot put any antivirus and update.
after that shut down your system and put that old hard disk with new one and before access that hard disk scan it properly .
Jan 02, 2013 | Buffalo Technology DriveStation HD-HC500U2...
The Hardrive is now beeping and the blue light only flashes once. And my laptop isn't recognising it. Everything I have is stored on it?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 24, 2012 | Buffalo Technology Buffalo MiniStation...
I just dropped my buffallo HD-CE500U2-EU and now its making a whirling clicking noise.. wont recognise on my laptop still lights up green though, can i fix this or at least get my files recovered? thanks
Sorry to said that your description comes to a dead hard disk. Especially if the hard disk was at power on state the moment that dropped down there is no doubt that the clicking noise that you hear is a destroyed hard disk.
Sorry for the bad news.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jan 29, 2011 | Buffalo Technology (USA), INC. - 500GB...
Formatting a buffalo hd-ce500u2
Jan 30, 2010 | Buffalo Technology DriveStation HD-HC500U2...
Buffalo drivestation 500 gb wont start
Chris
Jul 08, 2009 | Buffalo Technology DriveStation HD-HC500U2...
Mp3 has QHM5021-S-BE serial is not working properly
YOU SHOULD TRY TO CHANGE THE DATA CABLE!!!!!!!!!!!!!!!!!!
Jan 23, 2009 | Audio Players & Recorders
Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
237 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
