Question about Micro Application Dreamfall: The Longest Journey for Xbox
I can't seem to get April to overhear the conversation on the balcony. That,s the Alchera level. What am I doing wrong. I have walked crouched etc. to the ajar door nothing is working for me . Gina
  • sunnyfield Mar 25, 2009
    I am having the same problem. I have tried every button in every position on this balcony and nothing. Walkthru's make it look like it should be simple, but nothing works.
Flys gathering on my patio, in a shaded area under my balcony
In Georgia we rely on old fashion fly paper strips . hang a few from the balcony. Ace Hardware has them
May 20, 2017 | Cars & Trucks
Mary Noble
Mary Noble! Now thats a nice Oirish name! ( coming from a Hennessy)
Give me a little more info, if you will.
You have wifi at home ( for TV, PC, that sort of thing)?
I don't know your level of Techie , so please don't be offended by any suggestions, etc. Its just that I see your request has been here since April! Unreasonable!
Apr 26, 2013 | Apple iPhone4 4G iPhone 4
Some of my game characters on Super Mario World (Mario) look choppy or are unrecognizable while others on the same screen are clear. The game seems to play ok but I can't see what Mario should be...
General Game Pak Troubleshooting (NES and Super NES)
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance. If the problem you are experiencing is with just one game, please follow the steps below. If the problem is with all games, please visit the troubleshooting section for the system you have, by clicking here.
  1. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  2. Insert the Game Pak into the system. The Game Pak label should be facing the front of the machine (or facing up if you are using an original NES).
  3. Make sure the Game Pak firmly clicks down into place.
  4. Remove all accessories to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  5. Check the instruction manual for the game to see if it requires any special accessories to operate (such as the Super Scope, NES Zapper, SNES Mouse, etc.).
  6. Do not blow into your Game Paks or systems. The moisture in your breath can corrode and contaminate the pin connectors.
If these steps do not eliminate the symptoms you're experiencing with your game, we recommend purchasing a replacement from a retailer or online auction site that carries older products. For more information, click here
Aug 13, 2011 | Nintendo Super NES Console
Well maybe that they are bad gamepacks then like the intenal parts to the gamepacks have glitches because that they are old then and broken. But the worse possiblity would be that your super nintendo is on its way out so buy stuff from reputable sellers like lukie games or jj games then.
images?q=tbn:and9gcrvo2mdnp9euzq22x9tziduihrqrlotnpwkt0bh_ooroj8ncdic7u0lz-w images?q=tbn:and9gcrio1imk_w5cshphgc3shx4wdvshljp76i_rx5iirao3kedjptdnu4cgg
Aug 12, 2011 | Nintendo Super NES Console
Top Shot doesn't work (only Nunchuk style) Need an option to tell Wii I want the use the trigger with Z button. ?Nunchuk works (walk,crouch, etc.)
Same happened to me. Here's the fix... While in the game go to options. Now click on the top of the menu wher it says CONTROLS. You will then see the option to select Top Shot style. At first it seems like the word CONTROLS is just a header but it is actually a button you must select. Hope that helps.
Dec 05, 2009 | Activision Cabela's Big Game Hunter for...
Indiana Jpnes DS
The obvious answer is to walk up to them and keep walking. i just turned it on and replayed the level to clarify...and you just walk up to them and keep walking. if your having trouble maybe your walking of the wrong cliffs or not doing something right.
Sep 08, 2009 | LucasArts Entertainment Company Lego...
1ST LEVEL,WHERE DO i FIND KEYS TO THE GARDEN
COURTYARD WITH PALM TREES AND TIGHTROPE: Enter cautiously, Larson waits in the next room, up on a balcony to the left. Let him have it with your pistols and he'll run off shortly. Pick up a small medipak in the alcove on the right. Then go through the doorway below where Larson was standing. First go left down the ramp to a room with boxes. Here you'll find a GARDEN KEY (shaped like a star) on one crate.
Return to the hallway and continue left to the top. Larson will shoot at Lara again from the other side of the gap. Again, plug him a few times to scare him off. Then tightrope walk across to the opposite balcony. Drop down and, if you like, use the switch to open a gate leading back to the FOUNTAIN COURTYARD. (NOTE: As before, you don't have to do this, but it could save you some backtracking.)
Head away from the gate toward a WIDER STREET WITH A GATED GARDEN off to the right. This is where you'll use the GARDEN KEY, but you need another one first. Go to the left end of the street and through the small, square doorway. Follow the hallway, picking up some revolver bullets in a small room on the left. Make a mental note of the LOCKED WOODEN GATE with the small room behind it. This is the location of the second secret. You'll come back for it later.
Continue upstairs. Be sure to pick up the REVOLVER on the landing. (You probably won't miss it because the camera focuses on it so you're unable to look at anything else.) At the top of the ramp, push open the blue double doors. Inside this SMALL ROOM WITH WINE BARRELS you'll find the LASER SIGHT on the floor to the left and a padlocked gate on the right. Shoot the padlock: either use the revolver equipped with the laser sight to target it (check your instruction booklet or see the section on 'using the laser sight' on the TR5 controls page), or face the lock squarely and shoot continuously with pistols while crouching. Lara should hit the lock on the way down. Behind the gate is the second GARDEN KEY. A colony of rats swarms out. Some of these will try to bite Lara, so if you've gotten everything, run away downstairs. Or, run out, jump the railing and wait for the bats to disperse before returning to collect the key.
May 26, 2009 | Eidos Interactive Tomb Raider: Chronicles...
Pali april conversion
Questions about PALI? Give Baby Cribs Plus customer service a call at (800) 349-9131, Mon-Fri 8-9, Sat and Sun 10-5 EST or e-mail us at service@babycribsplus.com
May 19, 2008 | Pali April Crib
Micro Application Dreamfall: The Longest Journey for Xbox Logo
Top Micro Application Video Game Consoles & Games Experts
James Wishart
Are you a Micro Application Video Game Console and Game Expert? Answer questions, earn points and help others
