Question about Waterway Executive 48 Spa Pump 2hp 1spd 2" 34108301 ()
We have an older version waterway executive 48 pump with top outlet 75mm thread and front outlet 90mm thread we live in australia and need to replace it can you give me some help on wher we can purchase one thanks
    Scholar:
  • 111 Answers
It sound like that's the 2.5" x 2" wet end.
Spa Parts Shop can help you, they also ship internationally.
You didn't mention a Horse Power. The motors HP is likely wrong listed so provide them with the amperage of your motor as well.
Posted on Oct 30, 2012
4 Suggested Answers
  • 3600 Answers
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Posted on Jul 05, 2009
SOURCE: How do you remove the impeller
Take off the back of the motor, put a wrench on the shaft and turn the impeller by hand to loosen. It may be reverse threaded.
Posted on Oct 26, 2009
koaheart
SOURCE: hi , my executive 48 pump is leaking water at the
Actually a new pump is only $50, why bother replacing a seal with the uncertainty it may not work properly.
Posted on Aug 10, 2012
Waterway pump four wires res white black green which is ground old pump1.5 hp had three connectors plus screw ground new pump has four connectors plus screw ground
make sure new one is wired for 120 volt then the black goes to the L1 the white to L2 then the green to ground or case make sure to change brown and white to accomidate 120 volts
May 17, 2014 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
How do i remove pump from motor to repair or replace
Thank you for posting your question here on Fixya.com.
Remove the front cover on the pump and the shaft cover on the opposite end (back of the motor). Once the covers are off you can lock the motor shaft at one end using a screwdriver or wrench and then turn off the impeller counter-clockwise. Once the impeller is off you can remove the rest of the pump by loosening the 4 thru-bolts in the motor.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Nov 28, 2010 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Hi , my executive 48 pump is leaking water at the shaft ...... is this some sort of bearing or seal problem ? thanks in advance for any help , andy dic
The pump seal is the problem and it can lead to bearing damage if not caught soon enough. The seal used in the waterway pump is not as easy as most seals to replace. You are better off to have it done at a pump repair shop or pool store than to tackle it yourself unless you are familiar with this seal and have the tools to fix it. A repair bill would likely be under $75 for a seal replacement at a shop and they can replace the bearings if necessary.
John
Oct 07, 2010 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Can't get the pump apart to replace leaking seal.
if seal has been leaking probably ruined motor just replace whole pump and motor
Jun 24, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
I have a Waterly Executive Pump PF-40-2N22C\r\nI
Waterway did change the wet ends slightly (the difference is only minute and you wouldn't realise without meausring) and if yours is the older version you may need to change the entire wet end.
I'd advise you to take the pump to someone who can advise you and perhaps consider changing the entire wet end so that you have a new mechanical seal too.
If you're in the UK I can possibly help but I suspect that you're in the US...
http://hottub.synthasite.com
Regards,
Ian.
Jun 04, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
What size o rings do I need for the pump on my 2000 coast spa?
If you're talking about the O-rings that are on the pump unions you will need to measure your pump.
Measure the diameter of the thread on the pump...
1.5": Pump thread measures approx. 2-3/8" O.D.
2.0": Pump thread measures approx. 3" O.D.
2.5": Pump (intake) thread measures approx. 3-5/8" O.D.
Any reputable hot tub dealer should be able to supply you with O-rings if you tell them what size unions your pump has. The most common is 2".
Kind Regards,
Ian.
Apr 19, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Is any one else out ther with a Waterways 56 pump replacing them every 3 years also?
The UK versions of the Waterway pumps seem to be very reliable. The only known issue is with the Run/Start capacitors which tend to fail but they're easily replaced.
Over the years I've heard of many pumps being changed unnecessarily.
Regards,
Ian.
Jan 31, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
How do you remove the impeller from a Waterway Executive 48 spa pump
Oct 07, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Waterway Executive 48 Spa Pump 2hp 1spd 2" 34108301 () Logo
110 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
