Question about Coffee Makers & Espresso Machines
My Saeco Royal Professional brew unit is blocked. I cleaned it and the message goes away sometimes and then the gear won't turn the brewing unit so it can connect with the water valve. When I trick the switches and leave door open, I only see the gear turning clockwise when it needs to turn the other way in order to move the brewing unit correctly so water can come out. Maybe a reset would do but not sure what the deal is. Now is showing the brew unit block message again. Help!
  • Raf52 Nov 02, 2012
    I think if there is way I can reset the unit gear, this will fix it, but as of now it still keep on turning on reverse therefore it thinks the brew unit is blocked.
2 Suggested Answers
  • 9 Answers
SOURCE: brew unit blocked message The brew unit removed
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Posted on Nov 30, 2011
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
I have a Saeco Royal Professional bought in 2001. It has been an awesome machine. I changed the boiler in 2005 and replaced the O-rings in 2009. It has been decalcified fairly regularly. Last month, I...
Hi
Sorry to tell you but Brew Unit Block is usually the CPU or the main board going bad. It is usually caused by a constant drag on the brew unit causing more power going to the drive motor causing the CPU and the main board to heat up weaking the CPU or main board to the failure point. To much coffee going into the brw unit and causing the brew drive motor to work harder to compress the coffee will also do the same. You will have to replace the CPU or the main board. It is usually the CPU.
Mar 31, 2011 | Saeco Royal Professional Espresso Machine
Hi, My saeco royal cappuccino is displaying, brew unit block. It has been checked and all is clear. It was suggested that maybe it was the gearbox? Is this possible, if so do you have an exploded view of...
the saeco brew unit is the same as a Miele brew unit from a cva 615. check to see if there are any Miele service centers near you. The brew unit needs to be lubricated with food grade silicone grease every 30 days. if you dont do that, the plastic gears in the gearbox can and will strip. Try to find another brew unit and see if it works with a different one. If not, you may need to send it in to a repair center.
Nov 20, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
W/o manual I have a brew unit miss message?
Hi
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
The machine makes funny noises at start up then no water goes through the brew group.
The brew unit needs to be lubricated, and the shower screen needs to be cleaned.
Nov 21, 2009 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
Dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Loud clicking and no coffee
Looks like your brew drive gears may be stripped. You should have a professional look at it because some must be causing the struggle to happen.
Saeco Service and Parts
www.cerinicoffee.com
Nov 26, 2007 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
137 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
