Question about Mitsubishi VS-45607 45" Rear Projection Television
Ghostly vertical lines
A couple of weeks ago I cleaned the interior of my Mitsubishi VS 45607 RPTV. Cleaned the lenses, mirror, and wiped the back of the screen. I now have about seven vertical lines across the screen (kinda like dark to light, back to dark). The lines are all the same size, evenly spaced and across the whole screen and are best seen on a black image. They also disapear when the TV is not showing anything or off, so they are not streaks. I adjusted the convergence with no issues. Other than the "ghosts" the picture is great. Any suggestions???
    Genius:
  • 1,074 Answers
You have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
Posted on May 14, 2007
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi 55'' rear projection 1080i hd tv lense cleaning
Pry off the lower speaker grill... Remove the screws at the lower edge of the screen framing and lift screen frame of the two catches at the top. Be careful, there will be wires still attached to the front button panel... Then lay the screen down and support the bottom of it in some way because the button panel wires won't reach all the way... then using windex and papertowel cleam the mirror and lens(s) on each of the crts. Also clean the back or inside of the screen area and reverse the process to re-mount the screen.
Bill
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Screen removal from vs45va2
If you want to clean the projection lenses, you do not want to remove the cover screen to get there. That is the hard way, but you should be an experienced technician to do this correctly. Why do you think that the lenses need to be cleaned? What are you seeing on the screen to make you think that the lens needs cleaning?
Nov 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Vs-45607 mitsubishi tv
Try Re-soldering the vertical yoke connections and vertical output IC. This is quite common with this model.
Sep 23, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
380 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
