Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Ruud pacemaker relief valve
  • Rheem Master
  • 5,089 Answers
Copy following link for testing, and replacing TP valve
http://waterheatertimer.org/How-to-replace-TP-valve.html
Posted on Oct 27, 2012
I am looking for magnesium anode rod for an electric Ruud pacemaker 10 gallon water heater model# PEP 10-1 and serial # 0598304245. Do you know the parts number? Bill
no
try contacting the manufacturer for the part or talk with a plumber supplies shop ( where plumbers get their supplies and parts ) to see if it is available
it will be a sacrificial rod to prevent the tank from corroding out especially around the heating element fittings
Jan 29, 2017 | Water Water Heaters
Water dripping from blowpipe
It is normal for water to drip out sometimes from the pressure relief valve outlet pipe. If it drips continuously then open and shut the pressure relief valve several times so the pressure relief valve shuts off properly.
If this does not fix the dripping problem then the pressure relief valve is faulty and needs to be replaced.
Apr 02, 2013 | Water Heaters
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10...
sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Dec 01, 2012 | Water Heaters
How to drain ruud pacemaker water heater
Turn off water, turn off power, drain tank:
Copy following link for illustrations
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Aug 26, 2012 | Water Heaters
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    My relief valve slowly drips when my boiler runs, fills up a 5 gallon bucket in a day, when it runs alot. this is new ,
    Is the pressure in the boiler higher than the set pressure of the relief valve? If it is, there is a problem that the relief valve is trying to correct.
    If not, did you try making the valve open?
    Be careful, but step back, lift the lever and briefly let the relief valve discharge into a bucket of some sort, maybe you could put some old rags in it to keep from spraying out at you. If there is sediment in the valve this may flush it out.
    Dec 06, 2010 | Watts 3/4 Pressure Relief Valve
    My Rhem Ruud G76-200 water heater leaking from below? Can this be repaired?
    If it is actually leaking from the bottom of the heater, then it cannot be repaired. Have you looked to see exactly where the water is coming from? Sometimes a leak at the top of the heater, will then leak through the insulation and out the bottom. Another possible source could be from the temperature/pressure relief valve leaking and coming out of the down pipe that goes near the floor or drain. Try to find the source of the leak. It is not practical or safe to repair a tank that is leaking.
    Oct 03, 2010 | Rheem Tank Water Heater G76-200, 76 Gallon
    Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
    69 people viewed this question
    Top Rheem Water Heaters Experts
    Donni Steen
    gizmonix
    Level 1 Expert
    Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
