Question about Casio G-Shock GW300CA-1V Wrist Watch
Reset the time on my Casio GW300
I just change the battery after 3 years of use. I need to reset the time, day and date. Have missed placed the instruction book.
When out of broadcast range for a time signal, the online manual procedure works for me:
Posted on Feb 09, 2011
  • 3 Answers
Shouldn't the watch reset itself after it syncs with the atomic timeserver (which happens automatically in the early morning hours)? You can also manually force it to receive the time signal by holding down the the lower left "RECEIVE" button for a couple of seconds -- but make sure you do this near window to improve reception.
Posted on Jan 05, 2009
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly.....
check page 2
Mar 02, 2016 | Casio DW-5600E-1VCT Wrist Watch
Wrong date and time
When was the last time you replaced the battery? It might need a new battery.
Thank you,
Oct 22, 2013 | Casio Watches
Problem with day/date changes! My casio edifice
follow these instructions off the manual below if you set the watch in wrong sequens it wont change at 12 oclock
Sep 27, 2013 | Watches
I have a 3054. About 3 days ago it reset to 1-1-2005 and has never changed. it now reads 1-3-2005 at 5:57 PM
This same problem (watch resetting to 1/1/205) has happened to me 2x now, about 2 months or so apart.
I have had this watch for ~10+ years now, and works perfectly.
I have replaced the battery 2x.
Again, the watch works great.
I just realized that in the .pdf manual, there is no indication for a "low-battery" condition.
I am guessing that the "low-battery" is what is causing the watch to reset the date/time to 1/1/2005.
Any others having this same problem if this watch resetting to 1/1/2005 after the watch has run just great (auto time syncing, etc.)?
This watch Keeps great time!
Buster Brown
Jul 25, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do i change the time on the gw300.. i no longer have the instructions
you can get
instructions from the Casio web site.
Go to the casio web site "".
Select "support" and the "manuals",
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 04, 2010 | Casio Atomic-Solar Watch GW300
Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
Feb 05, 2010 | Casio Watches
Reset itslelf. WIll not display correct time, day, or year
My Casio wave ceptor keep resetting itself like this when the bottom right (D button) is pressed. I need to make sure I reset the city code or before trying to receive as it defaults to Tokyo. Press & hold the top left (A button) and date changes to city code. Scrole through codes using right bottons.
Hope this helps.
May 29, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio GW300 (2608) battery replacement
Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
Here is a site that has good instructions on how to change the battery in your G-Shock watch.
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
Jan 04, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Replace battery on a casio gshock.
good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Dec 16, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
2,035 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
