Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
My sony trinitron tv sometimes turns on then right back off or turns on volume only then few days later it works fine. whats up?
    Top Expert:
  • Sony Master
  • 75,571 Answers
Check for any loose solder connections in the main power regulator section of this TV. It will be very difficult to detect loose solder terminals, as they will be microscopically small to ***** eye. It is best to re-solder all the suspected solder terminals by applying a little more fresh solder to each solder terminals.
Posted on Oct 27, 2012
  • 308 Answers
SOURCE: sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Posted on Dec 24, 2006
SOURCE: SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Posted on Oct 25, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
Posted on Jan 31, 2008
  • 1121 Answers
SOURCE: have a Sony Trinitron TV that is in Standby Mode.
is a power supply problem. needs to be repaired. send to repair.
Posted on Feb 19, 2010
  • 1274 Answers
SOURCE: I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Posted on Feb 23, 2010
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony wega kv-34xbr800 doesn't turn on sometimes
You need to replace 2 ic part MCZ3001D located on the fron of the board on the left side
Sep 11, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
36" sony trinitron
Hi
you have defective starting capacitor! that is located in power section! or in the H.O.T. Area.
Thanks!
Sep 04, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV will be on for 2 hours sometimes, or 20 minutes then goes off, standby bottom is flashing. and keeps doing that over and over.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Volume gone mad
Is there a ceiling fan in the same room? Under the right conditions, light reflecting off the whirling blades hits the TVs sensor at just the right frequency, causing mysterious things like this. Try covering the infrared sensor on the TV (it should be behind a red transparent piece of plastic somewhere in the front. If this keeps it from "going mad", then something in the room is to blame. If it still does it even when the sensor is covered, then it is the TV. Good luck, and let us know what you find!
Mar 23, 2007 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
