Question about Husqvarna Garden
Kill switch on husqvarna 350 doesn't work
  • 37 Answers
Husqvarna 350 has a problem with the wire coming loose at the switch, Remove the top cover and next to switch on the left at the back of the saw the blue wire will be loose it should insert into the red switch, Expand the metal clip slightly and place back into switch for a snug fit.
Posted on Sep 28, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 100 Answers
Call your local or home repair shop/do not kill the motor by choking it out. also you may just have a wire come loose.
Posted on Oct 27, 2012
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
Got a 4 channel amp but can only use 2 channels, dont know why//
Did you check the fuses on the amp. If one of them has blown, this will shut it down. You will also need to check to make sure your RCA cables from the unit aren't crimped. This could kill the signal. Have you swaped the RCA cables to see if the other side works. If so and it still doesn't, check thos fuses. If this still doesn't help, you may have internal problems with your amp. Hope this helps
Aug 19, 2011 | Car Audio & Video
Hi I just bought a husqvarna 55 and once it worms up, it doesn't want to run at full throttle, as if it is starving for gas. I haven't changed gas filters yet, but after that I don't know...
Basic stuff first, replace the fuel filter in the tank on the end of the fuel hose, clean the air filter, if fitted check the spark arrestor in the muffler is not blocked, check the fuel hose for splits or leaks, check the rubber induction tube between the cylinder and the carb for splits.
Jun 01, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Kill switch doesn't work, how do i fix it?
The switch connects directly to the coil body of the ignition module. You may have to remove the left side cover to expose the ignition module. The switch, when off, connects this wire to engine ground. There may be debris in the contacts of the switch that prevent contact. You will have to remove the air cleaner assembly and maybe the carburetor itself to access the switch. Good luck!
Dec 22, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Kill switch will not stop motor
Check and make sure the wires are plugged into switch.If that don,t work it has a bad switch.
Nov 30, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a husqvarna 36 chainsaw that starts and runs just fine. However, the stop switch doesnt seem to work. I push the switch to stop and the saw continues to run. The only way to kill it is to use the...
Hi
Yeah,your switch has gone bad,and using the choke isn't how you want to kill it for too long.Fouled Plugs.Here's a link to the service manual pdf if you want to do it yourself. Shouldn't be too hard.
Please rate my post?
Bob
http://www.airtimeproducts.com.au/assets/docs/Husqvarna%20service%20Manual.pdf
Aug 13, 2010 | Husqvarna Garden
Husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Jul 15, 2009 | Husqvarna Garden
Garden Logo
599 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
