GRACO INC 16D559 - TrueCoat Pro Lithium Battery Charger Logo
Paul Roberts Posted on Oct 26, 2012
My batteries are not charging on graco truecoat airless
I used both batteries on a job and yhe charger would not charge them . It shows a green light as if they are fully charged
My battery charger is blinking geen not red when I’m trying to charge it. What does that mean?
Hi Linda.
not sure if this will help you out,i found this on the internet.
Battery Charger Troubleshooter
When there is a battery failure, there is a possibility it was caused by a bad battery charger. When the charger is only plugged into the wall, it should show a green light. If there is no light showing, confirm that the outlet is good. If the outlet is good, it is very possible that the issue is with the battery charger, not the battery.
If the charger is plugged into the battery only, it should show a green light. (If you have purchased a new charger within the last year, you will not get a green light if the charger is only plugged into the battery. You will get a green light however if the wall charger is just plugged into the wall and not plugged into the wiring harness) If it does not show a green light, it is likely that the charger is not making contact with the battery. The most likely reason for this is a faulty fuse on the wiring harness. This fuse is a 2-amp automotive fuse, and it should be replaced with a 2 or 3-amp fuse available anywhere that sells auto parts. The fuse can blow out if there is a short in the charging system, or if the plug-in end of the wiring harness comes in contact with a battery terminal.
When the charger is plugged into both an electrical outlet and the battery, there should be a red light showing on the charger. A red light showing indicates that the charger is in contact with the battery and is actively charging the battery. Once the battery has reached a voltage level that is considered "fully charged" the red light changes to green. If after 24 hours the light has not changed to green there is no cause for alarm! Remember that when the light is red, the battery is being charged, and you will be able to use your system. After 24 hours or so, your battery is as charged as it is going to get, and if the light is still showing red you should disconnect the charger and go fishing. Replacement chargers and parts can be purchased directly from MarCum's website.
If you are really concerned about your battery, consider getting a basic volt meter to check the voltage of your battery. They can be bought for less than 20 dollars and will show you exactly what the voltage level of your battery is. If after 24 hours of charging your battery should have at least 12 volts (ideally 13-14 volts) and as long as it is over 12 volts it will work. If it is not at or above 12 volts you should consider replacing the battery. If your unit starts to malfunction while you are fishing, it would not come as a surprise that the voltage has dropped down to 11 volts or lower.
If the charger is plugged into the wall and battery, and you get a blinking light on the charger, it is very likely that the battery is faulty and should be replaced.
Batteries are an expendable item, and must be replaced periodically. Any store that sells ice fishing electronics will stock suitable batteries. You can also buy them at a specialty battery store, or by ordering one from our website.The batteries that you should use are the "Sealed Lead Acid" variety, they are 12 volts, and range from 7 to 9 amps. The more amps the battery has the longer it will run on a full charge. Your MarCum unit can be powered off of any battery that is 12 volts, even a large automotive or deep cycle batteries will work.
or go to this link and have a read up.
battery charger is blinking geen Google Search
Jun 14, 2018 • Cameras
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
3answers
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
2helpful
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
1helpful
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
3helpful
2answers
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
5helpful
How to use
with Nimh batteries you can charge them anytime, you dont have to run them down first like nicads. just put the batteries in the charger with the flat end (-) against the spring and plug it in. some models have a red light to show its chargeing and a green one to show its fully charged while others just have a light to show it is chargeing.
Top GRACO INC Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
